SOURCE: flashing EFO error code
spoke with electrolux and they tell me that it is over sudsing problem. The washer must use HE detergent or use only a the lowest amount on the cup.
SOURCE: what does efo mean
Electrolux Washer Fault Code for EFO or EF0
Drain Filter is Clogged. Resolution => Click lint filter for soap buildup or other debris. Check drain hose.
Oversudsing - A high efficiency detergent was not used.
Too much detergent was added. Resolution => Use only a high efficiency detergent. Follow manufacturer's recommendation for dosage. Amount may need to be adjusted for water temperature,
water hardness, load size and soil level.
Hot water doesn't enter washer - Hot water hose is connected to the wrong faucet. Hot water faucet is not turned on. Resolution => Connect hot water hose to hot water faucet and hot inlet on
washer. Be sure hot water faucet is fully opened. Check water heater.
SOURCE: EFO displayed on my machine while running and beeped.
EFO is not a Kenmore Error Code.
Zanussi & AEG EFO = Filter Blocked (low flow) and it is accessible from the bottom front of the machine.
1. there is a blockage in the filter or drain hose.takes too long to drain out.
2. over dosing of powder or liquid. again can cause an air lock in the pump which slows the drain pump down.
Check the filter and drain hose and test again. this fault will only come up at the end of a cycle.
You do not need to reset the machine to get rid of the fault code as this is automatically deleted.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
