I found this on an appliance forum. It sounds the same as your problem. They say the code is F5 E1. Apparently the door lock latch is stuck.
. Appliance Repair Forums
Sounds like a problem with the door lock, door switch or the door switch actuator. Door lock is usually a single assembly with the switch. Check the pin on the door first. Model # is probably mistyped, won't come up, so can't tell anything specific.
Is it pumping water? If not then pump is bad.
Is the door locking? If the door will not lock, the washer will not enter a spin mode. See if the lock light is lite on the console.
Check for continuity across the Door Lock, Spin Enable Switch when the switch actuator button is pressed in. If there is no continuity across the Door Lock, Spin Enable Switch, replace the Door Lock Switch Assembly.(Check for 120 vac across the Door Lock Wax Motor)
Please rate this solution and ask for further clarifications if needed.
sure sounds as if it is def a compressor overheating, now that the compressoe will be cooled it should work , but your right damage may be already done, the good news if any is that you should be covered under 5yr manufactures warr for compressor
I'm afraid I don't have a solution, just the same problem. Exactly this has just happened to me and I don't know what to do. Calling out an engineer will be too expensive and in the mean time, I can't do any washing.
Have you had any success yet?
