I had the same situation.. I bought a HDMI cable and everything works great....
These are directional...but worked great for me.
. Select Active Series High Speed HDMI Cable with RedMere Technology 25ft...
SOURCE: ilo 27 inch hdmi/dvi hd tv monitor
Hi, I'm afraid that not only a cable is needed but an analog (vga) to digital (dvi) converter/scaler as well. The iLo LCD Display V27DMBX-U12 can hook up to a PC using the DVI-I connection only. As you said, your computer has the standard 1D15 pin VGA connector. Another possibility is if your video card has a composite video output (normally a color yellow RCA female) or an S-Video output which will both connect direct to your iLo LCD Display V27DMBX-U12. For the RCA connection all you need is an ordinary RCA to RCA shielded wire cable and for the S-Video, an S to S Video cable will work. There is of course the question about the quality or the resolution. Good luck and hope that this be of some help to you. Pls post again how things turn up. Kind regards.
SOURCE: connecting my laptop to my tv
I have exactly the same problem with my Sony Vaio. It seems to be a problem with the graphic board. Samsung needs a special signal over vga to unlock the PC-mode. There are only few Laptop graphic boards which send this signal on startup.
I haven't found a solution yet. But you may try to get a newer driver from:
http://www.laptopvideo2go.com/
Please tell me it worked out for you.
SOURCE: Laptop to Samsung TV via VGA cable - unsuccessful !!
The greyed out option indicates that no signal has been detected. Page 30 of the operations manual lists the supported display settings. Make sure that the laptop "screen" is within this range. Also, try making sure that the laptop is connected BEFORE you power on the set. There may be a glitch there.
Keep us posted.
Dan
SOURCE: HOW TO CONNECT SAMSUNG LCD TV TO ACER ASPIRE
Atlast I got some help from the right people (Samsung)! I would like to share it with others facing the same problem:
If you are using the D-sub 15 pin jack (VGA Monitor Cable: make sure its 15 pin and NOT 14 pins), follow these steps:
a. Mostly the problem lies with the VGA cable. Make sure you have the right one (15 pin) and its securely attached at both ends. If you are not using the right VGA Cable, it means that there is no connection between your TV and Notebook. Your TV will show 'PC' in Grey in the Source Input list (Go to ‘Menu’ from the TV remote).
b. Both your Notebook and TV should be switched off when you are connecting the cable otherwise one of them might have a problem detecting the other one.
c. Try Pressing Fn + F5, F6, F7 (depends on which Notebook brand you are using) on your Notebook several times. At times, you will see some signs that the Notebook and TV are trying to connect. Select 'CRT' from list of displays available to you.
SOURCE: LG 37LC7D Connect to VGA from a PC
Your right. I just had the same "Invalid Input" issue as well and it completely relates to the resolution compatability with any VGA or HDMI connection. Check the LG website for the online manual if you don't have it and see the section on RGB-PC cable. There is a table that incdicates the Resolutions the LG product is capable of displaying.
Thanks for the help.
