20 Most Recent
Philips 32PF7421D 32 in. LCD HDTV Questions & Answers
Can you help with connecting
Check your laptop with the same VGA cord on some projector or a monitor. If it works there, then there is a problem with your TV's VGA switching circuit. If it does not work, then there is problem with either the VGA cord or laptop's VGA port. To rule out the possibility VGA cord , replace it with new one. Please give the feedback for this so that further diagnosis can be done, if you are comfortable with the TV's electronics.
8/9/2011 3:31:46 PM •
Philips...
Answered
on Aug 09, 2011
Need screw size to attach
Stand screws are shown in below image taken from service manual and part number is as follows..
STAND SCREW KIT A91F2UH ... 1ESA19986, replacement part number is 1ESA21715 and available in
PartStore.com for $3.59
Hope this will help.
Thanks.
5/8/2011 3:06:59 AM •
Philips...
Answered
on May 08, 2011
Where is my cable output
your output cable is in the back of your t.v. there is a color designated on its hole then you have to buy a a cable in any electronic shop like components cable or hdmi cable try to read the back panel of your tv
3/10/2011 2:06:47 AM •
Philips...
Answered
on Mar 10, 2011
How long should it take
Please elaborate your problem providing us with more details of the issue
Thanks for using FixYa.
6/15/2010 1:01:33 PM •
Philips...
Answered
on Jun 15, 2010
My computer recognizes the tv but the tv isn't
hello,
you have to use the HDMI cable to connect, it is a serial type connector and use the remote control to select the HDMI input on the remote .
On the remote control select the video source button Hope this help, thanks for asking
6/7/2010 8:10:26 PM •
Philips...
Answered
on Jun 07, 2010
Can the crystals on an lcd tv be reset, i have
Ur tv LCD Screen is Damage,can't not repair burn in problem.Only way to replaced the whole LCD screen.
Tv compannies don't sell out only LCD Screen,they only sell out as with new tv only.Live with the burn in,or save the tv as part for the new one same model u buy.
1/13/2010 8:55:34 PM •
Philips...
Answered
on Jan 13, 2010
Trying to connect laptop to Samsung HD LCD TV using VGA cable.
I had the same problem with my Samsung series 6 32" Lcd. After many hours of trying different settings and banging my head on the wall I found the solution. What the problem is your VGA cable not supporting the high resilotion of your Samsung TV. The simple solution is to buy a new VGA cable that supports HD. Take a look at this site you need something like this one! Hope this helps.....C
http://www.clearly-av.co.uk/PGM1110.html
10/9/2009 12:45:15 PM •
Philips...
Answered
on Oct 09, 2009
