20 Most Recent Dell Latitude D620 Laptop (Latitude-C620) PC Notebook Questions & Answers
2answers
A dst short test fail code 1000 0141 comes when booting English: DST = disk test Dell tells me HDD is bad.
buy a new hard drive and clone your existing drive to it.The drive is headed for failure
12/16/2019 2:16:19 PM • Dell Latitude... • Answered on Dec 16, 2019
2answers
Can't start on battery but can run on it
Hello, it would be good to know if the Laptop has valid its guarantee and on the other hand if it receives battery charge, without making some measurements it's difficult to give an accurate diagnosis; it's possible that it's an element of the board (circuit) it's necessary to measure the voltage and other components to determine if there is a problem with the voltage delivered by the charger. We can perform a battery reset to check and have an idea.
5/8/2019 5:45:45 PM • Dell Latitude... • Answered on May 08, 2019
Only amber light flashing continuously and battery meter gadget shows the full battery but laptop does not come
Buy a new battery, may show as fully charged but does not output to laptop, i had same problem bought new battery fault solved.
11/9/2018 2:38:06 PM • Dell Latitude... • Answered on Nov 09, 2018
My laptop screen blinks
air hose blow out the processor fan /I bet its overheating/or bad memory
7/26/2017 3:40:22 AM • Dell Latitude... • Answered on Jul 26, 2017
4answers
Dell Latitude d620 lights but no boot
Your D620 probably has the Nvidia Graphics (Video) card that was a manufacturing defect well documented all over the internet. I have reflowed the video card on quite a few of these laptops. Below are some excerpts from the user manual.Solid green power light and no beep code and no video during POST The monitor or the graphics card may be faulty or incorrectly installed. Check the diagnostic lights to see if the specific problem is identified. See "Video and Monitor Problems."
1/9/2017 6:09:11 AM • Dell Latitude... • Answered on Jan 09, 2017
How do i use my dell laptop as a calculator
Open the Calculator program on the laptop (in Windows or Linux). Click on the start menu. Type Calculator. If your operating system doesn't support searching from the start menu then look in the application listing for Calculator..
3/6/2016 4:14:28 AM • Dell Latitude... • Answered on Mar 06, 2016
2answers
Is there a manual available?
Hi William, You may use the below link to find the user manual: http://dell.to/18tInOm Input the service tag, click on the pdf hyperlink next to owner's manual. Thanks and Regards. Kiran Kumar. #iworkfordell.
9/23/2015 7:05:23 AM • Dell Latitude... • Answered on Sep 23, 2015
Do I have to download ASK first. I have had problems from that area before?
Why should you download ASK? Ask is a dirty and trick adware and will fill your computer with advetising. People are crazy about trying to remove it! How to Remove Ask com
9/9/2015 11:50:28 PM • Dell Latitude... • Answered on Sep 09, 2015
Where can I download a manual
try either dell.com or manuals.com
9/9/2015 11:28:16 PM • Dell Latitude... • Answered on Sep 09, 2015
No soynd through LR Front Panel 3.5mm Jack
Double check to make sure there is nothing in any other 3.5 mm jack you can stick a q-tip that has had most of the stuffing ripped off and dipped in rubbing acohol to clean it off MUST BE OFF. 24575213-kdbydlvhgx3mczs4yctz3wk3-5-0.jpg if this doesnt work the built in speakers might have broken/blown or the built in audio might have a problem. But being a laptop you cant really replace the audio processor.
6/5/2015 11:28:37 PM • Dell Latitude... • Answered on Jun 05, 2015
4answers
HOW TO DOWNLOAD CAMERA SOFTWARE
Hi Lucky Siketho, Please email me the system service tag to [email protected] along with the current operating system installed. Then I can check and help you with the right Dell Camera application. Thanks and Regards. Kiran Kumar. #iworkfordell.
12/25/2014 2:45:21 AM • Dell Latitude... • Answered on Dec 25, 2014
I called a online help center and did what they said, now it will only start in safe mode with networking. how do i fix that
Check all sides of the laptop for a switch to turn on the wireless, if not you look at the keyboard make sure there is not a key that has the wireless on it . If you see the wireless on the key you must hold FN key and wireless key to activate. If the problem is not wireless, and it is just networking. Go in the control panel under network and sharing, open that and look for change advanced sharing settings (usually on the right side upper corner) open that and make sure turn on network discovery is on turn on all items ..
10/5/2014 1:23:03 PM • Dell Latitude... • Answered on Oct 05, 2014
I can't connect to the internet with my dell latitude d620 will factory reset fix this problem?
No. Factory reset wipes all settings and will require you to enter them again to get connected. You're better off using the help function in the Network Wizard to troubleshoot the problem step by step. If it's a windows machine it might be able to repair itself through this process.
10/5/2014 8:27:59 AM • Dell Latitude... • Answered on Oct 05, 2014
How to remove bios password with Dell d620 ?
if it is the password that pops in blue as soon as u start up mate the best bet buy the cd from ebay i have one but i found it easier going to the computer shop cause they have the hardware to do that plus if u google it pay a company who remove bios passwords you WILL HAVE TO REGISTER WITH them but make up something cause they ONLY do it for commercially goodluck if you dont get anywhere tell me and i,ll help you ok.
8/28/2014 4:40:44 PM • Dell Latitude... • Answered on Aug 28, 2014
I have a dell latitude D620 that the screen look blurred, i change the resolution to the highest but still blurred.
Hi, It is unfortunate that the LCD screen has blurred. There is a possibility that the LCD screen has failed. You may want to use the below link and performing an LCD BIST: http://dell.to/1irqbYp Also try connecting a known good external monitor and check if that helps. Thanks and Regards. Kiran Kumar. #iworkfordell.
7/10/2014 1:10:49 PM • Dell Latitude... • Answered on Jul 10, 2014
Computers & Internet Logo
199 questions posted
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
View Most Popular
LATITUDE Dell
  • LATITUDE Dell
Most Popular Question
called online help center did said now
  • Computers & Internet
