20 Most Recent Samsung LN-S4695D 46 in. LCD HDTV Questions & Answers
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts..
Samsung... | Answered on Mar 25, 2017
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Samsung... | Answered on Aug 16, 2014
It will be best to contact the authorized service center for Samsung in this case. They only can provide the component.
Samsung... | Answered on Nov 30, 2013
do you by chance have a pic of your old broken neck? I have a few Samsung pedestals in stock.
Samsung... | Answered on Dec 06, 2012
I would recommend you get a professional diagnosis. There is high voltage present in the set that can harm you. Being that you never messed with a TV, you could possibly cause more damage to your set. These flat panel TV contain sensitive circuitry. What you are describing sound like a fault with either the power supply or main board.
Samsung... | Answered on Dec 01, 2012
Are these vertical lines colored or do they look like static lines? Also are these lines present even on the no-signal screen? It sounds like an LCD controller problem but first I would like to make sure that its not the video precessing board. So please provide this info.
Samsung... | Answered on Oct 01, 2012
Hello
You can buy its original remote control from the Authorised Service Center for Samsung at your town. All functions of the TV can't be controlled by any universal remote control. Some functions may even accessed. If you have the original remote control with you now, you can buy it from any electronic sparepart shops at your town. It will have a number, and should be noted when buying a new one. You can also buy it, either from "Ebay" or "Alibaba.com" by e-payment. Just give them the exact model number of your TV. They will have its number and will send to you by courier. OK.
Samsung... | Answered on Sep 02, 2011
There is no way to replace just the screen.Mainly because the separate price of the panel can be more expensive than the tv itself. You can try at service center but you will have to pay a lot because this is not covered by warranty.
Samsung... | Answered on May 10, 2011
If you have a picture and it is all staticy and pixelated, then it probably is coming from the service your connected to these newer sets are much different today.
There's very little chance of an LCD TV having a "60 cycle hum". That problem was a hazard of CRT TVs and is rarely seen on LCD TVs and even when it is, it's mainly a problem with the RF feed and not the TV itself.
Try hooking up various inputs one at a time. For example try component input from a VHS tape player. Then try HDMI input for a HD player (Blu-Ray or HD-DVD). Then try a computer hooked up to the VGA input (set your video output on the computer for the native resoilution of your TV). Make sure you have the inputs selected correctly for each source.
The standard "refresh" rate for your TV is 60 Hz but that is a bit of a misnomer as LCD TVs don't used a raster scan for their display so their "refresh" is typically measured in miliseconds, in your case it is 8ms.
Your problem could be a power supply problem or if the lines are static, it could be an addressing problem in the ATSC decoder chip.
There are many other possiblilities but with more data on your symptoms, I wouldn't like to guess.
Hope this helps.
Samsung... | Answered on Mar 28, 2011
yes this is due to bad caps I have replace dozens of caps for samsung tv's you can do it your self or have some body do it for you or ship the power board to me
Samsung... | Answered on Sep 11, 2010
Samsung LN-S4695D 46 in. LCD HDTV Logo
40 questions posted
Jerry Greenberg
Jerry Greenberg
Ekse
View Most Popular
LN Samsung
  • LN Samsung
Most Popular Question
our tv screen droken
  • Televison & Video
