i'm just starting a new hobby of computer case modding and I'm just wondering what the best type of dremel to use. I'll be drilling small holes for M3 screws and cutting away at ABS plastic.I will also be sanding and polishing the ABS plastic as well. Any help would be appreciated.
Thanks,
Ron
SOURCE: Dremel 395 Type 2
Dremel Authorized Service Center
4631 East Sunny Dunes
Palm Springs, CA 92264
(800) 275-2052
Rob Dremel
they have the part you need for $1.25
hello,
try to find it here:
http://www.powertoolspares.com/parts2.php?model_ID=3057
may this help.
melnavz
SOURCE: need new variable speed switch for dremel 395 type 1
Someone else recently asked the same question and got the following solution;
http://www.fixya.com/support/t1515699-variable_speed_switch_dremel_395_get
SOURCE: Dremel Model 395 Type 3 Plastic Drive Shaft
You can call Dremel direct at 1-800-437-3635 and order the part. Let me know if you need more information.
SOURCE: I own a Dremel model 395 type 5 variable speed and
I would recommend going to Dremel.com and asking their tech section about this. I have one also and mine works fine other than a small amount of heat at the spindle area.
