20 Most Recent Dremel 395 Variable Speed Multipro Rotary Tool Kit Questions & Answers
You can call Dremel direct at 1-800-437-3635 and order the part. Let me know if you need more information.
Dremel 395... | Answered on Oct 25, 2018
go to Http://www.dremel.com/en-us/AttachmentsAndAccessories/Pages/Attachments.aspx
Dremel 395... | Answered on Aug 22, 2014
high speed buffing will break down the glaze. there are several liquid stain removers available that may work better, and do less damage to your tile. hope this helps.
Dremel 395... | Answered on Nov 13, 2013
I had to completely dismantle my dremel because both brushes were stuck. Had to basically break them apart because they were seized solid in there.
Dremel 395... | Answered on Oct 31, 2013
Something amazing just happened! On my monitor screen, window popped up that said, "ASK A QUESTION - LET OUR EXPERTS SOLVE YOUR PROBLEM FOR FREE".
I couldn't resist getting expert advice for free, so I clicked on the window. I was immediately taken to a magical world where I can pay for expert advice. I opted not to pay for expert advice. The next day, I was asked if the help I received was helpful. So here I am posting this response. I haven't received any expert advice yet, but when I do....!
Dremel 395... | Answered on Aug 11, 2012
coupler probably is destroyed. that is what happened to me. it is a fail safe to prevent motor overload
Dremel 395... | Answered on Jul 08, 2011
Check the brushes (under the two plastic screws). Link to manual:- https://mdm.boschwebservices.com/MDMCache/English%20%5BUS%5D//t10/0000000/r00129v-1.pdf
Dremel 395... | Answered on Jun 13, 2011
My dremel started doing that too. If I rubbed the sanding drum along a piece of wood, it would start up again. I think the brushes and the copper armature get glazed over with non conductive dust and possibly insulation smoke which disconnects it enough to stall out. Change the brushes to the new ones in the kit. After a year of heavy use mine slowwed down to about 300 rpm and then died. A very nice tool but I prefer the Makita which is about three times this size just because it is longer lived.
Dremel 395... | Answered on Apr 10, 2011
http://www.dremel.com/en-us/projectsandcommunity/projects/Pages/default.aspx
this website is directly from dremel. It shows different projects, crafts, or hobbies you can use it for. It is a real simple tool to use, and also is very handy. You can obtain several types of bits for it ones for sanding, engrving, cutting all types of materials, and much much more. Hope this helps
Dremel 395... | Answered on Jan 23, 2011
Try at eReplacementParts.com : Power Tool Parts and Tool Repair Diagrams.
If you need more help come back.Post / thumbs / testimonial are welcome!
Dremel 395... | Answered on Nov 28, 2010
Dremel 395... | Answered on Nov 19, 2010
Try some W-D40 and gentle hits on the coupling to liberate the chuck 3 pin holders.If you got this type of chuck:
r00130v1.jpg > Enlarge Image
4486 Dremel Chuck
The Dremel Chuck holds Dremel accessories without using a collet eliminating having to use the wrench and creating quick and e
Dremel 395... | Answered on Nov 08, 2010
Go to Dremmel.
Dremel 395... | Answered on Nov 05, 2010
http://www.dremel.com/en-us/AttachmentsAndAccessories/Pages/Attachments.aspx
Dremel 395... | Answered on Nov 02, 2010
The part that goes between the motor and the chuck is called the CLUTCH UNIT,
REF 2615294309 it is a splined rubberised sleeve, it also fits the 276 and 396.
The price is £3.69 (including vat at17.5%) and can be obtained from Jaymac (Derby) Ltd.
http://www.dremel-direct.com/acatalog/service.html
Dremel 395... | Answered on Sep 26, 2010
Either side of the body are two round plastic caps with a slot in under these are a spring attached to the brush, what you need to do is unscrew the cap with a small screwdriver or the end of the collet nut spanner, and withdraw the spring and carbon brush, check the length of the brush and replace if worn down, replace the brush cap and run the tool without load for five minutes to bed the new brushes in. (if the brushes are ok make sure you replace them in the same orientation as removed).
Dremel 395 Variable Speed Multipro Rotary Tool Kit Logo
40 questions posted
Top Dremel Tools & Hardware - Others Experts
cluffermon
Level 1 Expert
Mike
Van Allen II
Van Allen II
Are you a Dremel Tool and Hardware - Other Expert? Answer questions, earn points and help others
View Most Popular
  • Dremel Tools & Hardware - Others
Most Popular Question
tried replace motor brush dremel one bru
  • Tools & Hardware - Others
