20 Most Recent
Dremel 300 1/40A "Multi Pro" Rotary Tool Kit Questions & Answers
I have a Dremel model
Well, yes you can measure the switch, look for continuity. I suspect something else is wrong, some models had armature issues. Measure the coils and armature for continuity.
Trouble connecting flexidrve to the rotary tool
I would go to dremel.com for information they also have a tech service number there that can help. I had it but misplaced it. Let me know if you still have trouble and I will find more information
I cant loosen the head on the dremel 300
Another suggestion: you could put a point on that rod with a grinder or a file, or a dremel, and it's good as new.
Charlie
Could I get a "problem solved" / "fixya" rating on this -- there are icons at the bottom of this posting I believe.
thanks...
I inherited a Dremel Pro from my son who passed away...
you should have a little wrench that came with it
and on the neck of the dremel there is a shaft stop button
push the button and manually rotate the dremel head till
it clicks then hold the button and use the wrench to loosen the bit
Looking for the service manual for a weller mini shop model 601 Dremel tool
I'm sorry, but I don't have access to specific service manuals for individual tools. However, here are some steps you can follow to find a service manual for your Weller Mini Shop Model 601 Dremel tool:
- Visit the Weller website: The Weller website may have a library of manuals for its products, including the Mini Shop Model 601.
- Check the manufacturer's support page: Most manufacturers have a support page on their website where you can find user manuals, FAQs, and other resources.
- Search online: You can also try searching online for a digital copy of the manual. Websites like ManualsLib and ManualsOnline may have the manual you need.
- Contact the manufacturer: If you're unable to find the manual online, you can contact the manufacturer directly and request a copy. You may need to provide your tool's model number and other information.
I hope this helps you find the service manual for your Weller Mini Shop Model 601 Dremel tool.
