20 Most Recent Dremel Variable - Speed Multipro Rotary Tool 395 Questions & Answers
3answers
My Dremel lock nut won't budge. My collet is
You'll need to use either the built in shaft lock to hold the collet in a fixed position, or use a pair of slip joint pliers to hold the shaft of the bit, while you use the wrench to loosen the collet. Slow and steady should get it loose. Another option is use some penetrating oil sprayed lightly onto the back of the collet to help loosen it from the shaft etc.
11/17/2022 1:17:54 PM • Dremel Variable... • Answered on Nov 17, 2022
2answers
Changing dremel heads
I have exactly the same unit a 395. The kit comes w/ a wrench to unscrew the nut holding whatever you have locked in. If you can't find the wrench then I suggest you get an adjustable wrench and lock it into the flat side of the nut. There is a place where it will lock in so that you can tighten or loosen the nut. Some of the 395's come as a kit w/ all the different attachments, accessories, heads and tools. If it came with a plastic case the wrench is usually slotted running parallel just in front of the handle. You will see it when you open the case and take a top view look at the handle. It is sometime hard to see but it's just there. Good luck.
6/8/2022 3:33:31 PM • Dremel Variable... • Answered on Jun 08, 2022
3answers
My Dremel tool motor still works but shaft won't turn?
Here's the email from I got from Dremel (in my case the flex coupling broke):
Inside the tool is a flex coupling and spline driver.
The flex coupling is # 2615294309 and the price is $ 1.25.
This is the hollow plastic sleeve about 1" long with grooves on the
inside, that goes between the motor shaft and the output shaft.
The spline driver is # 2615294308 at $ 1.00.
Spline driver sits on the direct end of the motor shaft. The flex
coupling sits over the spline driver. Spline driver is about 1/4",
hard plastic with grooves on the outside.
Total shipping for orders under $ 5.00 is $ 2.50. Orders over $
5.00 is $ 4.00.
I have provided ordering instructions below.
To order by phone: 1-800-437-3635, Monday-Friday from 7 am to 6 pm
central time. VISA, MasterCard or Discover is accepted.
To order by mail:
Dremel
4915 21st Street
Racine WI 53406
6/7/2022 8:22:38 PM • Dremel Variable... • Answered on Jun 07, 2022
I have a brand new Dremel 8000-03. It died after
More supports, please refer to www.dieselgeneratortech.com
4/11/2020 2:59:26 AM • Dremel Variable... • Answered on Apr 11, 2020
Coupler on shaft is broken
Look at eReplacementParts.com and the parts diagrams,
If you need more help come back.Post / thumbs / testimonial are welcome!
10/25/2018 8:26:55 AM • Dremel Variable... • Answered on Oct 25, 2018
Flex shaft attachment won't work
find the little square attachment and place on the end of the dremel tool. I didid the same thing. Worked fine after I put the other part on.
10/25/2018 8:26:34 AM • Dremel Variable... • Answered on Oct 25, 2018
I took apart my Dremel
It doesn't attach anywhere, that's why it popped out. It should just fit in a recess, pushing the lock button outward.
10/25/2018 8:25:41 AM • Dremel Variable... • Answered on Oct 25, 2018
2answers
Craftsman rotary tool doesn't lock down on the bits.
the collet is either the wrong size for the shaft on the attachment or is missing alltogether
10/25/2018 8:22:19 AM • Dremel Variable... • Answered on Oct 25, 2018
5answers
My collet nut is stuck and I cannot remove it. Is
remove all the star head screws, unscrew the top plastic collet holding the plastic outer casing on. take a pair of vise grip locking pliers open the plastic casing just enough to expose the inner shaft inside the casing lock the vice grips onto the metal shaft between the bearing casing and the collet that is stuck enough to hold but not to dent it up. now that the vice grips are locked onto the main shaft get an adjustable wrench and size it to the collet screw size and turn it should come off rather easily or at least mine did just did it as i wrote this then screw the casing back together and happy dremeling hope this helps
8/17/2018 7:52:03 AM • Dremel Variable... • Answered on Aug 17, 2018
How do i take the bit off of a dremel multipro
unscrew the collet nut, and then if it's still stuck, tap the end of the bit on the table or something solid. It'll come loose then.
8/9/2018 3:00:30 PM • Dremel Variable... • Answered on Aug 09, 2018
I have a Dremel Moto-Shop
http://www.condeyor.com/Dremel_Scroll_Saw_571.htm
7/30/2018 4:06:37 AM • Dremel Variable... • Answered on Jul 30, 2018
2answers
Dremel 300 Series - I can't get a collet to go in
There is a collet stuck in there. It was probably in there without any tool in place, then the collet nut was tightened. With no tool filling the hole in the collet, it collapsed and became small enough to be pushed too far in. Fortunately these collets are soft steel. Find a sheet metal screw that you can screw into the hole. That will allow you to pull the collet out. Discard that collet. These collets come in at least two sized to accommodate different sizes of tool shafts. Unfortunately the spare one you have is one of those sizes, and the one you extracted is probably the other. But they don't cost much and you can buy them where you buy dremel tools. Good luck, Al K
3/12/2018 10:21:08 AM • Dremel Variable... • Answered on Mar 12, 2018
I have a Dremel Mod395 Type 5 and I am living in
Hello, M8052895 - I found a list of authorized Demel repair centers in the Philippines here: http://www.dremel.com.ph/ph/en/service/after-sales-service/dremel-authorised-service-centre-list/ If you scroll down that page, you will find a Philippines contact telephone number. Best wishes.
3/5/2018 7:42:46 PM • Dremel Variable... • Answered on Mar 05, 2018
The flexible shaft core is broken can it be replaced and how part No.2610914543
http://www.searspartsdirect.com/part-number/2610914543/0009/170.html
4/18/2015 3:50:19 PM • Dremel Variable... • Answered on Apr 18, 2015
2answers
Dremel while runnibg cuts out if i wiggle the case
Hi it sounds like you have a brush worn out. I would change out the brushes first and go from there. Brushes are relatively cheap and it is a good investment to check out first. You can get brushes from almost any hardware store that sells Dremel parts and accessories.
1/3/2015 2:42:29 AM • Dremel Variable... • Answered on Jan 03, 2015
Dremel rotary tool variable speed, low speed speeds up after short use. Will brush replacement solve this issue?
How stable is your line voltage? The SCR phase control used for speed control is more sensitive to line voltage changes at low speeds than at high speeds. Brushes should be changed when they are worn down to about 1/2 of their original length. Much more than this and they don't have enough tension to properly contact the commutator ring. Check with power off when the tool is cold and slowly turn the chuck by hand to feel the resistance. Run it a while and let the bearings warm up. Turn off power and turn by hand again. If it feels looser when warm (which would cause it to speed up at slow speeds), the tool might need to be disassembled and bearings oiled. I use Dexron automatic transmission fluid to lube most motors. Wipe down any excess.
11/29/2014 12:00:30 AM • Dremel Variable... • Answered on Nov 29, 2014
Dremel Variable - Speed Multipro Rotary Tool 395 Logo
197 questions posted
Top Dremel Tools & Hardware - Others Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Dremel Tool and Hardware - Other Expert? Answer questions, earn points and help others
View Most Popular
  • Dremel Tools & Hardware - Others
Most Popular Question
flexible extension not working dremel
  • Tools & Hardware - Others
