American Standard 2004.014 - Champion Elongated One-Piece Toilet Logo
Posted on Jan 11, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Water seem to be leaking trough the seal constantly and every so often keeps filling
Anonymous
Level 3:
  • American Sta... Master 43,501 Answers
  • Posted on Jan 11, 2010
Anonymous
Level 3:
Answers
43501
Questions
0
Helped
10845694
Points
101584
The problem is yout toilet flapper. It will look something like this.
You can find a new one at most hardware stores or at a stoe similar to a Lowe's or Home Depot. Changing them is very easy, usually they are held by two ears on either side of the standpipe. Just remove the old one, hook on the new one and adjust the chain to the lever so that it flushes properly.
These are made of soft plastic or rubber and are affected by stuff in the water. Chlorine especially is hard on them and makes them hard and brittle, causing them not to seal right.
Sometimes dirt will accumulate on the bottom and wiping the bottom off will fix the problem, but it is usually a temporary fix.
Heatman101
Eco Flush. Why does it keep running?
A dual flush toilet is a fantastic option to save water and make your home more environmentally friendly. Giving you the option for a half flush or full flush at your discretion, you can lower your water consumption while still getting the job done. However, like all toilets, they can present problems that mean the toilet doesn't function as it should. One common problem in dual flush toilets is constantly running. You hear the tank constantly being filled, even when it should be finished and completely full. If your dual flush toilet is constantly running, first check for the top three problems that cause this trouble:
Flapper or Seal Trouble
The flapper or seal is often the culprit in constant running water in both normal and dual flush toilets. Over time, this rubber piece may become brittle or simply misaligned. To check it, turn off the water supply and flush the toilet to completely empty it of water. Remove any remaining water with a sponge or towel. Then, you'll need to remove the flush valve canister in order to access the seal. Once you've found the seal, check to see if there are any cracks in the seal. If there are, you'll need to replace it. Otherwise, check to see if it can be re-aligned to sit nicely in its place. Some homeowners find that applying a bit of Vaseline to the seal can renew it, making it supple and functional again for a while at least.
Debris
Sometimes the water supply isn't as clean as we think. Or, dust and dirt may be able to enter the toilet, causing the fill valve to malfunction. To check it, turn off the water supply and remove the lid from the fill valve. Then, look for any debris and remove it. You may also consider brushing out the valve with a small brush. Once you're certain it is clean, recap the valve and check if the problem has been solved.
Broken Zip Tie
The fill valve in most dual flush toilets has a zip tie to keep the base of the fill valve in place. If the fill valve isn't strongly secured, it can cause the toilet to run. Sometimes these ties wear out or break before the rest of the device does. You'll need to replace a broken zip tie with a new one if you find that it's broken. If possible, you can place two zip ties on the fill valve in order to assure that the base doesn't wobble, causing the leak. Many times these problems are easy for the average homeowner to check for and repair. In the case that you are not able to find a solution to your dual flush toilet's constant running, then you'll need to call in the help of a professional plumber. A high quality plumbing company will be able to help you troubleshoot your dual flush toilet troubles and make sure it's functioning properly again.
Apr 04, 2020 • Home
Why does dishwasher rinse light keeps flashing and sounds like its draining. ?cant put another programme on
the flashing rinse light is a error code but i need a model number to know exactly what it means, constant draining with an error normally indicates an issue with water either its filling up to much and leaking into the base or it has a leak from somewhere in the dishwasher i.e. a hole in hose or a leaking seal, constant draining is a default response to a leak for all dishwashers often continuing draining even when the door is opened
Oct 08, 2014 • Dishwashers
2answers
Not making enough ice
What is the ambient air temperature in the location it is installed??
My washing machine is over filling it is draining away but only if you put it on a spin the inlet water is constant and is always filling and wont cut off then it leaks from door seal and tray for washing...
Water inlet is controlled by a level switch and hot/cold water valves,( solenoids). It seems most likely that one of the water valve diaphragms is faulty;turn off hot and then cold taps to determine which one is leaking.A handy person can often strip the valve and replace the diaphragm, or else
a service person may be needed.
At times, the water is measured by weight,(depth) and during spray rinse by the timer, therefore, if you are using a cold rinse, ,most likely the cold valve is faulty.
Maytag washer top loading leaks water seems to be coming from the tub itself 7 years old thank you mija
does unit leak constant or only when spinning ther are 2 screws done low on front panel fill unit with water and watch center shaft there is a seal below basket
inside washer changing seal is a little difficult have also had this style of washer leak when starting spin cycle if water has not drained out fast enough
http://www.repairclinic.com/Washing-Machine-Top-Load-Maytag-Style-Appliance-Diagram
this page has a break down of normal maytag top load machine part at center is called boot and seal have also had thi type unit leak where bolts go through tub
good luck ron
Dec 12, 2009 • Cameras
1helpful
Drain trough at rear of fridge freezer constantly full of water . Drain hole appears to be clear. fills up every day
The evaporator fan may be drawing the water back up the drain hole when it comes off defrost. The drain might be trapping itself or the drain trough might not be allowing the water to travel to the drain hole. Another cause could be condensation and not the drain at all. Door seals may not be working properly.
My 2008 Corrolla has a gas leak? What causes this?
Your fuel gage sensor seal is not sealed properly
6helpful
2answers
Sub Zero 632 leaking water
Had the same problem on the same model (632). Turned out to be a plugged drain tube on the condensate collection trough located on back wall of the refrigerator. Simply pull out the crisper drawer (the drawer below the lowest shelf) and you'll bee the trough. The drip tube can easily be plugged by a vegetable leak or grape, etc which had fallen into this trough. Hope its as simple for you as for us.
Simpson Silencio 850 leaks - the water doesn't seem to stop filling. Replaced all seals, but it keeps filling until it leaks and we have to stop it manually.
Hi, I've just purchased a 2nd hand model of your dishwasher. mine actually leaks from the black lining underneath. I've just patched it with some Sellys bathroom sealant. I don't know more about your problem but sounds like it could be something not timing out to stop the water, maybe buy a new 1 :P
Sep 11, 2008 • Dishwashers
4helpful
3answers
Prewash flashing and machine Overfilling
Their is a small bowl connected by a see trough plastic pipe leading up to the preshour switch, that you will have to clean out the bowl and disconect the pipe from the presure switch and blow trough this to clean out any droplets of water. Replace then try the machine again, it may fill up again, dont dispair, empty the machine and re-blow trough the hose again with it disconected from the preshure switch. To empty the machine of water place the outlet hose into a bucket 3 or 4 times.
slimjim1
Top American Standard Home Experts
john h
Mike Cairns
Mike Cairns
deton8 von Splosion
Are you an American Standard Home Expert? Answer questions, earn points and help others
