Go to Control Pannel and Add remove Programs
and
Uninstall the HP Photosmart 8250 Inkjet Printer Drivers
or
Click start - control pannel - System - Hardware - Device manager - Select the Printer (+) and uninstall the Drivers
then Check by connecting the USB Cable to the Computer without installing the drivers
IF its NOT SHOWING " Found New Hardware Message " - then Please make sure the Printer is on / check replacing the USB Cable - the install the Drivers
If it should show the Found New Hardware Message - then we can deside to install the drivers for the Product
Then download the Updated drivers from HP Photosmart 8250
if above link don't work then
chek : http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=443024&lc=en&cc=us&dlc=en&lang=en&cc=us
According to the Operating System ..
I have an HP Photsmart C4100 printer. I purchased remanufactured ink cartridges (both black and tri-colored) from Vivasmart. The black one works fine, but when I installed the tri-color, I got an error message that says "Print cartridge problem" The following print cartridge has a problem:
Tri-color. And I can't print. The screen on my printer says "Remove and check color cartridge." I have done this several times and it still won't print. I have turned off the power, removed the cartridges, and unplugged the unit, but it still didn't help. Any suggestions?
