20 Most Recent HP PSC 1510 All-In-One InkJet Printer Questions & Answers
Go To Below official HP Printer Page For Your problem,http://h30434.www3.hp.com/t5/Other-Printing-Questions/Printer-Paper-Jam/td-p/126558
Still having Problem Then follow Us For HP Printer Support
HP PSC 1510... | Answered on Mar 27, 2018
Download the Support Assistant and check out other help on the HP website
HP Deskjet 1510 All in One Printer Software and Drivers
HP PSC 1510... | Answered on Oct 25, 2017
HP are notorious for this sort of error reporting, not very helpful at all.
On your first point; Is the cartridge an original HP cartridge? If it is then remove it and re insert it pushing it home firmly. If not then either get a cartridge from a reputable clone supplier or use a genuine HP one.
Next point; Inspect the paper route minutely for debris and identify and clean the paper switch, which is a tiny micro-switch and can become jammed closed just with paper dust.
The Scrivener
HP PSC 1510... | Answered on Oct 12, 2017
Forget Macs! Current PC's work just as well and you can buy software for the latter. Try that with a mac or try getting peripherals that do not cost an arm and a leg. And they are notoriously overpriced.
HP PSC 1510... | Answered on Aug 28, 2017
The cradle is out of mechanical sync and hitting the travel limit stops.
HP PSC 1510... | Answered on Aug 15, 2017
Right click on setup.exe. Properties -> Compatibility -> Run this program in compatibility mode for: Windows XP
HP PSC 1510... | Answered on Dec 09, 2016
There are feed rollers that pull the paper through. When they get a slick spot on them, they will not feed properly or not at all. This will be your first remedy, to replace them.
HP PSC 1510... | Answered on May 14, 2016
I am almost certain that printers that have an external power adaptor will NOT have a user replaceable fuse inside the printer.
Check power adaptor or wall outlet.
HP PSC 1510... | Answered on Mar 15, 2016
Question is, was it printing correct before you refilled?
If not, the refill perhaps was not needed. Perhaps only cleaning the print head coulld have been enough. Print a head alignement page (just a little ink is used and only a few lines are printed) to check all the nozzles. When you see missing parts, you know you have to run one or a few cleaning cycles. When you don't use the printer often, please at least once a week switch it on and after a few minutes switch it of again. It will perform a cleaning cycle then, making the chanche of cloging minimal.
HP PSC 1510... | Answered on Apr 01, 2015
734 questions posted
Clive
Clive
View Most Popular
  • HP Office Equipment & Supplies
Most Popular Question
make font larger hp1510 printer
  • Office Equipment & Supplies
