The HP Pavilion DV6000 is one in a popular line of consumer-oriented laptops produced by HP. Relatively inexpensive, the
Pavilion DV6000
is a good all-around value for most users. Taking apart an HP Pavilion
DV6000 is not an easy chore and if you plan to use the laptop again, it
is important you know what you are doing or you have a large appetite
for risk. If the above doesn’t describe you, consider taking the HP in
for professional repair or upgrade. Otherwise, follow the steps below
to disassemble the
HP Pavilion DV6000.
1、Prepare a clear workstation. Turn off the laptop and remove all
power components including the cord and the battery. (Turn the laptop
over and you will find the tab to push and pop out the
dv6000 battery.) Also remove any peripheral attachments like card readers and USB devices.
2、Turn the HP Pavilion
dv6000
upside down and unscrew all the screws you find. Try to keep them
separate by size so you can put them back in the same spot when and if
you decide to reassemble the laptop.
3、Remove the hard drive and memory modules by pulling up on the
rectangular compartments. The memory is located in the central
compartment (remove by spreading latches and pulling up), and in most
HP models the hard drive is located to one side.
4、Remove the optical CD/
DVD drive
by pulling on the drive face to the left and out of the laptop. Remove
the WiFi card by disconnecting the gold connectors on the antenna and
pulling the card from its slot.
5、Turn the
hp dv6000
back over and remove the keyboard and power panel/media touch pad.
Carefully pry the power panel up with a piece of hard plastic near the
power button on the left side. Be careful when pulling not to yank the
power connection as you might accidentally rip out a wire. Pull back
the keyboard to reveal the connections. Disconnect the connections by
carefully pulling on the tabs with your thumb and forefinger. If they
are tight, wiggle them back and forth while pulling on them to loosen
them.
6、Remove the screws that were underneath the power pack/media touch pad. Carefully pry up the top casing and set it aside.
7、Detach all visible connections to the motherboard by pulling
gently on them, wiggling them if they are stuck. Gently pull up from
the right side of the motherboard and remove. The HP laptop is now
fully disassembled.
