Kenmore 22422 Top Load Washer Logo
Posted on Jan 04, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My kenmore model 110 limited edition will fill with water but wiil not wash spin or drain. ther is no motor noise but the digital timer counts down
  • mammafeets Jan 09, 2010
    how do u remove belt from kenmore 70 series
Anonymous
Level 3:
President:
  • Master 1,937 Answers
  • Posted on Jan 04, 2010
Anonymous
Master
Level 3:
President:
Answers
1937
Questions
0
Helped
430228
Points
5400
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Newer model Whirlpool / Kenmore washers use a Lid Switch as a safety device. Unless the switch senses that the lid on the washer is closed, the washer will neither agitate nor spin.
Older models only used the switch during the spin cycle.
Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
Following is a description of how to release the console for access to the pins.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
This is a Whirlpool PDF on how these washers operate. It has a diagram on jumping the switch as well as a detailed section on how the transmission works.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
It also has a troubleshooting guide.
To bypass the switch, you only have to disconnect the power to the washer, tilt the console back, unplug the switch and using an short piece of insulated wire, jump the two outermost contacts on the connector coming from the console and plug the washer back in.
Following is a description of how to gain access to the console and how to remove the cabinet if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=913ba652cd504fb162f87d892bcb427b
With the jumper in place, try to re-start the washer.
If it works, the Lid Switch is a relatively inexpensive part.
Kenmore washer Model 110, Serial No. 27602690 won't spin
If wash cycle operates and water drains as should before spin indicates motor spinning. Chances are bad timer If your a real fixer you can remove timer control from panel check and clean all contacts internally making sure none are stuck closed . (Have had 3 110s in my time).not easy but can be done or buy new about 150$ reassemble and check operation.
I have the kenmore elite oasis it turns on and just makes a little noise and counts down the minutes but doesnt fill up drain or spin.
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
1helpful
Our Kenmore Model 110 - 82980120, Stock 29801, 118 G is giving a problem with the Automatic Process. It does not move by itself. It stays at the same place it is kept. If Kept at Wash it stays there, if...
The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem: It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
It fills and agitates. Fills up then stops, makes a buzzing noise and will not drain or spin. What could be wrong?
in order to accurately diagnose this i will need the model number, but it could be that your lid switch is faulty, therefore not allowing your washer to go into a spin cycle. for safety reasons. another cause of this could be from a bad timer, if your timer stops after the agitation cycle and does not continue to count down then you have a bad timer.
1helpful
HELP!! Washer machine wont work. Doesnt drain or spin. Clicks to drain and spin but nothing happens, the timer still counts down as if everything is fine.
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
If the machine starts, fills and goes through its' agitate cycle fine, the problem is likely not in the motor or transmission.
This type of washer uses a reversible motor. When turning one way, the machine agitates the clothes.
When the timer gets to the spin cycle, the motor reverses, drives the pump (directly from the motor) for a period of time and then goes into spin cycle.
This appears then that is is either the connection to the motor itself or the timer.
The timer is driven by a separate motor on the control panel so if the contacts for the spin cycle are worn, the timer will move but the motor won't turn on.
1helpful
2answers
Washer Kenmore 80series Doesn't want to drain the water after it's RINSE CYCLE. No sound from motor or pump. It just stops. does it drain after the wash cycle? if it does, then I don't think it's the...
Solution for Washer Kenmore 80series stopped on SPIN CYCLE and no Drainage or motor running.
** What was stopping it to drain was the defective limit switch which when the cover lid is closed starts the spin and the drain at the same time. I jumped the wires to get my close washed and I have to replace it for security. I had to unscrew the front control panel and remove the casing that wraps around the washer to have access for the limit switch wireing harness. I cut the two black wires and joined them with a wirenut so that I was able to continue my wash and draining the water leftt over.
7helpful
2answers
Machine doesnot agitate or drain once filled with water
it sounds like a bad lid switch if it will not drain or spin,the switch controls that-mike
2answers
Washing machine won't spin
Do you hear the motor spinning loud whirring noise,when drum is not,if so drum belt has come off or snapped,if no noise possible brushes on motor need replacing
Alexander
vince
