Maytag MAH2400A Front Load Washer Logo
Posted on Dec 31, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The Maytag repairman says my model number is MAH2400AWW. You tell me: No manuals found for mah2400aww manuals. What now?
Greg Mills
Level 3:
President:
  • Master 497 Answers
  • Posted on Dec 31, 2009
Greg Mills
Master
Level 3:
President:
Answers
497
Questions
Helped
168484
Points
1563
Check for yourself, pull the washer out, and check the back. model numbers/serial numbers are normally tagged on the back.
1helpful
Message "suds" appeared on my Magtag laundry machine
There is a panel at the bottom front of your machine. Remove the 3 - 4 screws at the bottom of the panel. Inside the panel you will find Service Codes and other useful info. It's a good place to keep them so my advice is to put them back when done with them. It is indicating "suds" because you are either using too much detergent, wrong kind of detergent (make sure it's high-efficiency detergent) or you need to clean the catch basket on the drain pump.
The owner's manual can be downloaded here:
http://www.searspartsdirect.com/partsdirect/part-model/Maytag-Parts/Washer-Parts/user-manuals/manual-downloads/Model-MAH2400AWW/3048/0153200?modelNumber=MAH2400AWW&diagramPageId=&documentId=
Hope this helps.
How to repair nd code on a maytag mah2400aww washer
Remove the back panel (2 screws). On the bottom tray is the water discharge pump. Clear any obstructions.
Maytag washer leaking from bottom
This is a fix for the Maytag MAH2400AWW, the machine kept displaying SUDS, the machine is 2-3 years old and it started doing this 4-5 months ago. I cleaned out the washer, and used HE detergent, ran it empty, to try to flush it out, used approved cleaners and ran it throught the cycle, still no good. I finally took out out a maintenance contract with BSF, the service guy came out today pulled the pump off and showed me inside it was missing half of the blades off the impeller. I remembered a year ago a coin had wedged in the pump which I took out and put back, not realising it had taken some teeth off the pump. Therefore the pump was not able to pump out the sudsy water very well which was staying inside the drum causing the suds light to come on, they installed a new pump for me, which was covered in the contract for free. Now it's working like new again.
Where can I purchase a Y connector for a Maytag washer model#MAH2400AWW
I would guess that your local hardware shop should have them- they are quite common (the Y connector!)
Cheers,
John C
What is code 3E on a Maytag model MAH2400AWW
CODE 3E IS SOMETHING TO DO WITH THE MOTOR. MINE JUST WENT OUT AND TURNS OUT THE RELAY IS BAD TOO. HAVING TO GET A NEW WASHER. TOO EXPENSIVE TO FIX.
5helpful
MAH2400AWW washer won't drain
pump is plugged unplug washer lean back against wall under unit right front 2, 5/16 screws lets pump free take hoses on both sides free check for coins after pump and objects before pump and in pump clear reinstall if clear replace pump just had 2
1helpful
2answers
Maytag front loading washing machine
3E = Drive system is not working correctly. Bad windings, speed sensor, wiring connections or Control Board.
Top Maytag Washing Machines Experts
ZJ Limited
ZJ Limited
john h
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
