I have a power acoustik bamf 1600/4. the green and red leds are blinking back and forth and no sound will play from my sub??? worked the night before then stopped working the next morning. Weird.... Help Please????? I also looked in the manual and it said nothing about the green and red led flashing.
Use a multimeter to see if the amp has good power wire and remote turn on voltage. then check the ground and make sure its a good strong ground. check the sub to make sure its not bad. make sure it reads whatever ohm its supposed to. anything less than 4 ohms will clip the amp if bridged. if alll that is good then the only thing left is the amp. it sounds like the power supply is bad but check everything else just to make sure. good luck.
