20 Most Recent Power Acoustik TS1440-2 Car Audio Amplifier Questions & Answers
3answers
Protect Mode with RCA's
It sounds like you have some DC voltage on the RCA input.
You need to figure out if the problem is coming from the head unit or if it is in the amplifier.
If you have a voltage meter, you can use it to find out very quickly.
Set the meter for DC and for a max level of more than 12 volts. Most meters I use have a 30 volt level. That would be a good setting.
Take the black lead and make sure it is grounded to the chassis of the car or to the ground of the power terminal, be careful and make sure it does not touch anything else.
With the RCA cable disconnected put the red lead on the inner part of the RCA cable and see if there is any DC voltage and then check the ground or outer part of the cable. Do the same for the other channel as well.
It should be very close to zero volts. A couple of millivolts is fine to. Any voltage here will cause the amplifier to go into protect mode, which is what is happening to you. You will then need to have the head unit serviced.
If you have a Pioneer head unit, I have seen many of them with an open ground fuse for the RCA jack. That fuse is a surface mounted fuse and is very small and hard to locate on the main board of the radio. If you do have a Pioneer head unit the voltage may seem OK, but you will have an open ground, but that normally does not put the amp into protect. It makes the audio sound very weak and you would have a loud hum. I can help you with that if it turns out to be the problem.
If the voltage on both the RCA leads is OK, then you need to check the amplifier.
You can put the meter lead on the ground of the RCA jack on the amplifier, if you have anything abnormal there, you have a problem in the amplifier. Be careful checking this because you can easily touch the lead to the chassis of the amplifier at the same time as the RCA ground. Most of the time, if yu have a problem in the amplifier like the one you are having, this check of the RCA ground will result in some DC voltage on it. If it still checks OK, then put the lead into the RCA ground and check the positive part of it. You may need to move the lead around a little to get it to touch the metal inside, it is on the bottom part of the hole inside the jack.
I think you will find that you have some voltage on the RCA inputs of the amplifier. To fix this properly you will need to take it in to be serviced.
Sometimes you can ground the RCA jack ground somehow with a jumper wire and then turn the system on with the RCA cable plugged in and it will seem normal. But you do not want to do that as a repair, only to see if the amp will play. If it does play, you know that the problem is in the pre-amp of the amplifier. That would be the only reason to connect an external ground to the RCA jack. You still have a problem in the amplifier. If it does not play normal, you still have a problem in the amplifier if there was some DC on the RCA jack.
Sorry this answer is so long, but the problem you are having will require service of one of your units, you just need to know which one it is. If your inputs get grounded, you will not have the amp go into protect, you just won't hear anything.
Let me know if you need more help and if this was helpful to you a good rating is always appreciated.
7/31/2022 7:20:40 AM • Power Acoustik... • Answered on Jul 31, 2022
0answers
Ch4-600x
Be the first to answer 2/16/2013 4:31:03 AM • Power Acoustik... • Posted on Feb 16, 2013Be the first to answer
My 620 watt power acoustik amp is on protect mode
this is usually an anti theft precaution taken where if the amp is tampered or attempted to be stolen it will shut down making it useless for the thief the only way to get them unlocked is usually by the people whom installed it for you or the manufacturer
12/19/2010 11:25:22 AM • Power Acoustik... • Answered on Dec 19, 2010
My 620 watt is stuck in protect mode why is that
this is usually an anti theft precaution taken where if the amp is tampered or attepted to be stolen it will shut down making it useless for the thief the only way to get them unlocked is usually by the people whom installed it for you or the manufacturer
4/15/2010 1:51:42 AM • Power Acoustik... • Answered on Apr 15, 2010
Ampifier protection mode problems
I don't specifically know what kind of protection circuits Power Acoustik employs however I don't they have input short protection. You can verify it by just unplugging your RCA cables and if the unit still goes into protection the problem exists in the output stage.
1/5/2010 4:15:26 PM • Power Acoustik... • Answered on Jan 05, 2010
Car amp turns off when RCA wires are plugged in.
Hello joshua_m_moe,
A short or ground on the RCA cables or too high of an output level from the head unit could cause this. First, try it with the amp gain turned all the way down. Then, replace the cables with a known good pair. If the problem is still there, it's probably coming from the head unit. If there is another pair of preamp outputs, switch to them. If the problem still persists, I'd suspect the head unit.
Hope this helps.
9/20/2009 4:44:33 AM • Power Acoustik... • Answered on Sep 20, 2009
PLACE TO PUT FUSE IS BLOWN
i wud say u cud , did u take it too a shop?..
7/16/2009 12:33:42 AM • Power Acoustik... • Answered on Jul 16, 2009
Need power acoustik PADVD-360 instruction manual
Hello adrieltoyota,
Here is the link to Power Acoustik's contact page. I'd recommend contacting them directly.
Hope this helps.
4/26/2009 6:24:31 PM • Power Acoustik... • Answered on Apr 26, 2009
2answers
Protection light on
i had one of these amps, if you don't have a good ground, the protection light will come on.
3/18/2009 1:44:46 AM • Power Acoustik... • Answered on Mar 18, 2009
Odd behavior of power and protect
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp (not on the point where the ground wire connectes to the vehicle) and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. If the voltage is below ~11 volts, you need to check the wiring feeding whichever line is too low.
Do this with no RCA or speaker wires connected. Let me know what you find.
5/4/2008 10:43:02 PM • Power Acoustik... • Answered on May 04, 2008
Amp
try turning down the gain a little bit. or check the ground and power connections at amp and battery. they may be loose
2/25/2008 12:52:52 AM • Power Acoustik... • Answered on Feb 25, 2008
MH master
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. If the voltage is below ~11 volts, you need to check the wiring feeding whichever line is too low.
1/16/2008 10:17:43 PM • Power Acoustik... • Answered on Jan 16, 2008
600 watt 2 channel power acoustik sterling amp
On your amp, there should be a switch (on the side probably) that has "LP", "HP", and "FULL" or "OFF". This is a switch for the low pass/high pass filter. Switch it to "LP" as this will allow only low frequencies to go to your subs, what you want. If you don't have that switch, go to an audio store or online audio supplier and get either a low pass filter, band pass filter, or a cross-over, and follow the wiring diagram that comes with it to filter out the high frequencies before they get to your subs.
10/9/2007 1:50:09 PM • Power Acoustik... • Answered on Oct 09, 2007
Power Acoustik PD-624B 6.2-Inch Double-Din in-Dash LCD Touchscreen DVD Receiver with Bluetooth. The Radio cannot play any video, gives warning message.
Question edited for a lot more clarity, full make model (what it is)'. Question moved from Televisions category. The warning message may have been useful! People don't realise that factory car audio is operated by and monitored by the Body Control Module (BCM) on a computer network. Your warning chimes and indicator clickers are generated by the BCM and played through the car audio system. The computer has no idea that this new device is! Take it to an auto electrician or to an Alarm / Audio installer and see if their professional bi-directional grade scan tool computer can reprogram the BCM to ignore your device. Or just put the old one back. ..
2/15/2024 5:39:58 AM • Power Acoustik... • Answered on Feb 15, 2024
Power Acoustik single DIN DVD Receiver. It won't turn on?
Running straight power from the battery suggests there's another option, as for instance running mains power... How could having two ground wires work, please?
1/29/2024 7:10:57 PM • Power Acoustik... • Answered on Jan 29, 2024
Power Acoustik TS1440-2 Car Audio Amplifier Logo
24 questions posted
Top Power Acoustik Car Audio & Video Experts
Steve Sweetleaf
Steve Sweetleaf
ZJ Limited
ZJ Limited
Are you a Power Acoustik Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Power Acoustik Car Audio & Video
Most Popular Question
620 watt stuck in protect mode
  • Car Audio & Video
