20 Most Recent Power Acoustik LT-980/2 Car Audio Amplifier Questions & Answers
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty . A thumbs up would be greatly appreciated if this answer is helpful to you
Power Acoustik... | Answered on Feb 03, 2015
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty . .A thumbs up would be greatly appreciated if this answer is helpful to you
I have a Digital Audio model-DA2200W, Was listening to my tunes loud as always....then the subs quit bumpin...checked the subs cuz i thought i blew em...theyre fine...The power on the amp is still on...green light and all..just no output..I opened it up to see if anything looked burnt looks fine...is it toast or can i fix it??
Power Acoustik... | Answered on Dec 18, 2014
this is either cause by wires shorting outside of the amp or and internal short. if its internal is may be bad transistors
Power Acoustik... | Answered on Oct 09, 2013
Look on amp for a dial or button that says GAIN or LEVEL try adjusting
Power Acoustik... | Answered on Sep 08, 2011
According to a listing on epinions, it appears that the amp is 8 ohms per channel standard, and can be bridged to 4ohms.
One post says that he has it bridged to 4 ohms and is getting 560 watts of output.
I couldn't find a manual for it, so you may want to contact Power Acoustik to be sure.
Power Acoustik... | Answered on Aug 09, 2011
I find that most Amps that does this the transistors nearest the to the B+ side of the Amp is bad. there are anywhere from 4 to 6 a side and if you know anything of these you can check them remove and replace them. I have a different problem. the prower light comes on and the goes off and I am trying to find a schematic to trace down the problem. if I find it I can talk U through it and show pics.
J, Todd
joseph.todd51@yahoo.com
Power Acoustik... | Answered on Jun 24, 2011
its going into protect mode, meaning there is either a short in one of the transistors
or one of the jumper bars is loose, needs to be re-sodered. Easy fix.
Power Acoustik... | Answered on Jan 18, 2011
220 Watts X 2 @ 4 Ohm RMS
• 280 Watts X 2 @ 2 Ohm RMS
• 980 Watts X 1 Bridged Output
• 560 Watts X @ Mono RMS
Power Acoustik... | Answered on Oct 20, 2010
normally check the fuse (s) example if the fuse is 40 amps the amp can do 430 rms...
Power Acoustik... | Answered on Jun 24, 2010
you want to use a car amplfier indoors in the house
yeah that can be done very easily
just wire it like you would inside a car but you need to purchase a 12v DC adapter
i would go for one with at least 3A output (the bigger the better it depends on how much u wanna spend) from personal expericance 1.5A works but when it gets loud the amp stops and restarts
Power Acoustik... | Answered on May 18, 2010
Power and ground are touching. Either at the terminals or inside the amp itself.
Power Acoustik... | Answered on Apr 04, 2010
Look for popped Capacitors. These are the tiny cans that are on the circuit board. They usually buldge out on the top and leak white paste.
Good luck and i hope this helps.
Power Acoustik... | Answered on Jan 28, 2010
your rca cables or the wires running to the amp are loose and/or touching eachother. also check behind your head unit
Power Acoustik... | Answered on Jan 11, 2010
Power Acoustik LT-980/2 Car Audio Amplifier Logo
Popular Tags
68 questions posted
Top Power Acoustik Car Audio & Video Experts
Dalynn Turner
Marvin
Marvin
Are you a Power Acoustik Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Power Acoustik Car Audio & Video
Most Popular Question
like know watts or rms
  • Car Audio & Video
