20 Most Recent Power Acoustik PS2-1600 Car Audio Amplifier Questions & Answers
0answers
Red light is on
make sure the positive supply that is directly connected to your batteries positive terminal is properly connected
6/11/2010 12:00:34 AM • Power Acoustik... • Answered on Jun 11, 2010
Stayin on protect mode
before turning on disconnect speakers, power up the amp and check if it is still in protection
4/18/2010 6:36:52 PM • Power Acoustik... • Answered on Apr 18, 2010
Power acoustik ps2-1600 blowing fuses
Generally, this would indicate that the output transistors are shorted (which is generally a relatively simple repair). But an amplifier that never worked properly could indicate that it has a manufacturing defect. Sometimes, it's as simple as a bridged solder connection. Other times, it could be due to a missing component (which may be more difficult to repair).
The first thing you need to do is to check the output transistors. They will typically be the larger devices clamped to the heatsink. If you find any that are shorted (~0 ohms) between legs 2 and 3, you have at least one shorted transistor.
Before you do anything inside the amp, remove it from the power source and read the following page:
Basic Amp Repair
8/4/2008 7:20:13 PM • Power Acoustik... • Answered on Aug 04, 2008
Amp getting really hot
Disconnect the speaker wires and the RCA jacks from the amp.
If it still gets hot, the amp needs to be repaired.
If it doesn't get hot, check the impedance of the speakers and make sure they're wired properly.
If they are wired for the proper impedance, check each voice coil with an ohm meter to make sure none of the voice coils are shorted.
4/11/2008 10:54:53 PM • Power Acoustik... • Answered on Apr 11, 2008
Burnt smell
If something is burnt,something made it burn !! These things dont smoke for no reason. Have the amp checked out, and also have the speakers and all the wiring checked for a partial short. Good Luck
8/8/2006 2:12:51 AM • Power Acoustik... • Answered on Aug 08, 2006
Power Acoustik PD-624B 6.2-Inch Double-Din in-Dash LCD Touchscreen DVD Receiver with Bluetooth. The Radio cannot play any video, gives warning message.
Question edited for a lot more clarity, full make model (what it is)'. Question moved from Televisions category. The warning message may have been useful! People don't realise that factory car audio is operated by and monitored by the Body Control Module (BCM) on a computer network. Your warning chimes and indicator clickers are generated by the BCM and played through the car audio system. The computer has no idea that this new device is! Take it to an auto electrician or to an Alarm / Audio installer and see if their professional bi-directional grade scan tool computer can reprogram the BCM to ignore your device. Or just put the old one back. ..
2/15/2024 5:39:58 AM • Power Acoustik... • Answered on Feb 15, 2024
Power Acoustik single DIN DVD Receiver. It won't turn on?
Running straight power from the battery suggests there's another option, as for instance running mains power... How could having two ground wires work, please?
1/29/2024 7:10:57 PM • Power Acoustik... • Answered on Jan 29, 2024
2answers
My Power Acousik PD-651B is making a crackling, poping noise now when I turn it on
That usually happens when the switch is dirty. You can flood it with electrical contact cleaner. Also make sure the speaker connections are good and the polarity is correct. https://www.google.com/search?q=power+acoustik+pd-651b+makes+popping+noises ..
8/21/2023 11:58:59 PM • Power Acoustik... • Answered on Aug 21, 2023
I have a power Acoustik cpaa7dd double den car radio and I keep getting unknown disc errors
  1. Make sure the disc you are trying to play is compatible with the radio. The radio may not support certain formats or types of discs.
  2. Check the disc for any visible damage, such as scratches or fingerprints, that may be preventing it from playing properly.
  3. Check the CD player for any debris or foreign objects that may be preventing the disc from being read properly.
  4. If you are using an aftermarket CD changer, make sure it is properly connected to the radio and functioning correctly.
1/3/2023 11:26:18 PM • Power Acoustik... • Answered on Jan 03, 2023
I have a power acoustik 8920 not the 8920 b not the 8920t my power acoustic it has Smart control not Bluetooth is it the same thing when I hook up a USB it shows error instead of playing
From. My. Radio. Can. U. Show. M. What. Pin. Is. What. Color. Of. Wire. To. A. Power. Acoustic. Modelptid8920b
10/15/2022 4:13:59 AM • Power Acoustik... • Answered on Oct 15, 2022
My power acoustik pd-620hb won't turn off
POWER/MUTE Button Press it to turn on the unit.Press and hold for 2 seconds to turn the unit off . Press the button briefly to Mute . Please note that the volume will be muted on all audio output connector.
7/24/2022 5:31:48 AM • Power Acoustik... • Answered on Jul 24, 2022
POWER ACOUSTIK 1EG-7000D SERVICE MANUAL
Contact Power Acoustik or its distributor directly to request the manual.
3/29/2022 9:44:56 PM • Power Acoustik... • Answered on Mar 29, 2022
What is the wiring diagram for a power acoustik radio model ptid 8960 cannot find it ANYWGERE!
notify power acoustik support https://poweracoustik.com/
10/14/2021 11:17:44 AM • Power Acoustik... • Answered on Oct 14, 2021
I have a power acoustik pd 701 how do I play videos off my iPhone thru usb cable
  • Smart Control enables select Mobile 8 models to communicate with the media player of most Smartphones and tablets
  • Smart Control sends playback commands by the AUX cable connected to the headphone output of your smart device
  • Control track selection, play/pause, and even answer incoming calls. AUX cable included. Variable Subwoofer Pre-Amp Output
  • Play audio, video, and picture files through Mobile 8 from DVD, CD, or 32GB SD/USB flash drive. Supports MP3 & WAV audio files & MP4 video files, and JPG pictures.
  • Safely make and receive hands-free phone calls, scroll contacts lists, and stream MP3's via A2DP from your enabled Smartphone. Most Bluetooth enabled Smartphones seamlessly pair
4/17/2020 9:12:42 AM • Power Acoustik... • Answered on Apr 17, 2020
2answers
Power Acoustik Car DVD Player 103 Touchscreen PD103B will not play mp4 movie
MP4 is a codec that is not compatible with this DVD player. Your DVD player will play store bought DVDs just fine. Please read the specifications in the owners manual to see what codecs are compatible with your player.
11/28/2019 9:56:22 AM • Power Acoustik... • Answered on Nov 28, 2019
I have a Power Acoustik PD-710,,I cant get my USB to work. It keeps saying USB error. I have checked my usb on my laptop and other car stereo and it works. It dont work with the power acoutik
Okay I am assuming that you are referring to a USB thumb drive aka memory stick which contains mp3, wma (YOUR STEREO ONLY PLAYS MP3 AND WMA VIA USB NOTHING ELSE MANUAL SAYS) audio tracks and a certain specific format (formatting is done on computer, windows and different types of formats are supported on different devices). NTFS, fat32, exfat. Typically I think they like fat32 before but I have had all of my drives formatted for NTFS on newer equipment and had no issue with it. Um since you checked the drive and its working it's probably not that. It could be the connector on your stereo there. But if its new it's probably a formatting/compaitbility issue with the stereo. Heres the manual http://www.poweracoustik.com/pa2012/manuals/PD-710-T.pdf Also this stereo is a really cheap brand so they don't work as well and dont have that great of support. A Google search of that an similar stereos from them came up with several issues. There is very little USB power coming from that port so it's probably only enough power to connect a thumb drive. Some people have cables connecting to other devices and that is probably not going to work. I would get a different usb stick reformat it on the computer and copy some mp3's over.
11/1/2019 12:55:27 AM • Power Acoustik... • Answered on Nov 01, 2019
Power Acoustik PS2-1600 Car Audio Amplifier Logo
Popular Tags
7 questions posted
Top Power Acoustik Car Audio & Video Experts
Steve Sweetleaf
Steve Sweetleaf
ZJ Limited
ZJ Limited
Are you a Power Acoustik Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Power Acoustik Car Audio & Video
Most Popular Question
amp getting really hot
  • Car Audio & Video
