Try using "Tuner wash" if your lucky it's just a bad volume antenuator. It can be found at any electronics parts store. ie. Radio Shack. Pull the knob off, put a rag around any area that you do not want to spray, then spray the control. Let it sit for a couple, work the control back and forth then spray again. Let it set for a few then test. If that does not work you can replace the knob relatively inexpensively at Radio Shack as well. Hope this helps
