20 Most Recent
KLH ASW10-100 Subwoofer Questions & Answers
I turn on my subwoofer
You might have blown the speaker. This happens when you play things too loudly and you ruin the speaker inside. You can test this by playing something with a decent amount of bass and turned up a bit. If you hear like a "rattle" in the sound or like something isn't right in the heavy bass notes, then you definitely blew the speaker out. This isn't a tragedy. They're fixable if you bring them to a place that repairs speakers. But I would definitely test it first by hooking it up and playing a loud song with a lot of bass. Hope that helps a little! Please rate my solution!
- Frankie
My Subwooofer only works intermittently when I
Try using "Tuner wash" if your lucky it's just a bad volume antenuator. It can be found at any electronics parts store. ie. Radio Shack. Pull the knob off, put a rag around any area that you do not want to spray, then spray the control. Let it sit for a couple, work the control back and forth then spray again. Let it set for a few then test. If that does not work you can replace the knob relatively inexpensively at Radio Shack as well. Hope this helps
