Lanier UNKNOWN Logo
Posted on Dec 08, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I need an instruction manual for a lanier LD328c copier i need to program the scanner feature for the computers on my network
Amar Sondhi
Level 2:
Novelist:
  • Expert 122 Answers
  • Posted on Dec 08, 2009
Amar Sondhi
Expert
Level 2:
Novelist:
Answers
122
Questions
0
Helped
39207
Points
379
Hello, check out this link below here you will find all the drivers/software/management tools for this machine;
http://www.lanier.com/downloads/driverFrame.aspx?path=http://support.aficio.com/bb/html/dr_ut_e/lan_u/model/c35_45/c35_45en.htm
hope this helps
regards
Amar Sondhi
2answers
How can I connect a Lanier LD430c to a Windows 8 computer so that the scanner work
Lanier doesn't seem to have specific drivers for windows 8.1, but you may be able to use the windows 7 drivers, here:
http://www.lanier.com/downloads/driverFrame.aspx?path=http://support.aficio.com/bb/html/dr_ut_e/lan_u/model/e_3000/e_3000en.htm
Lanier 335c toner won't load
If the toner hopper assembly is not broken the mylars inside of it have fallen off over time. The toner supply unit needs to be replaced.
Not want to read the new toner
Very, very common issue on these normally related to a problem in the toner hopper assembly itself.
2answers
Lanier 5618 Network
Lanier 5618 is not a Network Copier. However, it may be installed on one PC and shared from there. Drivers are available from LANIER Official Support
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
We have a Lanier printer, copier, scanner & facsimile Machine type MPC 4500 and we cannot find any instructions. I would like to know, where do we put the stables in. I have looked every where.
Depending on what kind of finisher you have, the staples generally go in the lower left corner of the machine. You can download a product manual for your copier here:
http://ricoh-usa.com/downloads/downloads.aspx?d=pm
Search for "mp c4500" and when the results come up, click the link for Manuals next to where it says "Downloads". You'll have to agree to the site's terms of service, then you can download a PDF copy of the manual, with instructions for basic use and maintenance.
How do I remove the hard drive from a Lanier LD328c. This needs to be done for security reasons.
You should contact a Lanier or Ricoh service technician to remove the hard drives for you, but if you have to do it yourself the hard drives can be removed by unscrewing and sliding out the controller board (on the right side of the copier). The hard drives are connected to the controller board by three screws and four connectors.
Scan routing
http://www.lanier.com/downloads/driverFrame.aspx?path=http://support.aficio.com/bb/html/dr_ut_e/lan_u/model/x22_27/x22_27en.htm
Go to the above site and download your software and a manual, the manual tells you exactly how and what to do.
1helpful
I want to program email addresses on a Lanier LD050 copier/fax/scanner machine.
On the keyboard......User tools> administrator tools>address book.
you make your changes\ additions here.
You also must have your network settings completed in user tools. DNS, SMTP SERVER, GATEWAY ect....
Error SC101 on copier
No, you can't reset. You'll need a tech. Here's what the manual says: Symptom (SC101) - Exposure lamp error - The standard white level was not detected properly when scanning the white plate. Possible Cause: ? Exposure lamp defective ? Lamp stabilizer defective ? Exposure lamp connector defective ? Standard white plate dirty ? Scanner mirror or scanner lens out of position or dirty ? SBU defective
I cannot find a manual for my Lanier 5025 copier/scanner (Ricoh Aficio 200) and am unable to figure out how to change the identification settings for the fax. i.e.; put my id name and number on faxes. Does...
I'm going by my own memory here, so you may have to fool around a bit, but this should help. Manual is hard to come by for this old beast.
"user tools"
"fax"
Scroll to "key op. settings" (i believe you have to press "yes" or 'Ok" immediately after selecting this to access this feature??)
In there you should see settings for RTI/TTI. This is what you program for your Identifiers (use the 'quick dial' keys for entering text).
Good Luck ;)
Top Lanier Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
Are you a Lanier Televison and Video Expert? Answer questions, earn points and help others
