20 Most Recent Lanier Ld 430c With Feed, Bank, Print, Scan - 124k Copies Questions & Answers
Lanier doesn't seem to have specific drivers for windows 8.1, but you may be able to use the windows 7 drivers, here:
http://www.lanier.com/downloads/driverFrame.aspx?path=http://support.aficio.com/bb/html/dr_ut_e/lan_u/model/e_3000/e_3000en.htm
Lanier Ld 430c... | Answered on Oct 26, 2014
All printers are not equal. Some utilize cartridges with ink reservoirs and print heads all in one. Some only have a Separate Print head carrier with a main print head and slots for ink-filled reservoirs. You can purchase and use less expensive cartridges from on line vendors. If you elect to refill carts, be prepared for a messy venture. What many printer users fail to recognize, is the print heads do wear out and prior to complete failure, the heads either cause streaking or poor color density. To clean a print head, run under the tap for a few minutes, very hot water on both sides , metal bars and where the ink enters. When all signs of ink have vanished, replace in the printer. Do not touch metal contacts as oil will interrupt electrical communications. Do a printer test and alignment. Should work.
Lanier Office... | Answered on Feb 08, 2018
http://www.productmanuals.org/lp/?brand=Lanier&utm_source=adcenter&utm_medium=cpc&utm_term=lanier%20manual&utm_network={}&utm_campaign=FM+Brands+02-03+2
Lanier Office... | Answered on Jan 06, 2018
Are these new or refilled?
Lanier Office... | Answered on Nov 09, 2017
Lanier Ld 430c With Feed, Bank, Print, Scan - 124k Copies Logo
1 questions posted
Top Lanier Office Equipment & Supplies Experts
quennie732
Adorjani Laszlo
gggg
Are you a Lanier Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Lanier Office Equipment & Supplies
Most Popular Question
connect lanier ld430c windows 8 computer
  • Office Equipment & Supplies
