20 Most Recent Lanier UNKNOWN Questions & Answers
Hey there "Lanier" do you still have the Hiccups ? if so, I will tell you how to get rid of them in 30 seconds.
get a medium size glass (10-12oz) fill it to about 1" full from the top, now while standing up, drop your head down put the glass to your mouth so that your trying to drink off of the opposite side of the glass than you normally would, so that your chin is actually in the glass and so the bottom of the glass is going back towards your chest, now as you slowly bend forward from your waist, start drinking the water out of the glass, (its like your trying to take a drink in the opposite fashion that you normally would) . Now you might spill a little but its ok, you only need to drink a small amount of water, now when your bent over and have had a few swallows of water, keep your head bent down for 10 seconds or so and now stand back up and pour the rest of the water down the sink because your Hiccups are gone.
Here is why this works, (it's actually a biological plumbing thing) the " Hiccups " are nothing more than an air bubble in your digestive system, so by bending over and drinking the water in this fashion, it lets the water run into your system and the air bubble to escape over the top. ( BTW my dad taught me this trick in 1965 and I've cured a million cases of Hiccups, plus I've won a lot of money in the bars showing people how to do this ).
You can thank me later...
Lanier UNKNOWN | Answered on Sep 29, 2014
you may need a new washer in the tap
Lanier UNKNOWN | Answered on Aug 29, 2014
Try neutral if it doesn't start there then your lever and P R N D L are out of sync. You could also try pulling the little plug out of you consul and pushing down with a thin screwdriver on the switch in there then turn on the ignition switch if it starts then it's your neutral safety switch that has to be replaced by the dealer or a good shop that you trust. It should still fall under the vehicles warrenty though.
Lanier UNKNOWN | Answered on Jul 18, 2014
here are the causes of high CO:
Defective Oxygen Sensor
- Inoperative Air Injection System (if equipped)
- Leaking or defective Fuel Injectors
- Restricted air filter (especially if high CO is present only at high RPM)
- Vacuum leaks resulting in improper MAP sensor operation
- Defective air mass or air flow sensor
- Malfunctioning fuel evaporation system or purge valve
- Defective Catalytic Converter
- Defective thermostat (cooling system), thermostat stuck open
- Oil contaminated with fuel, excessive miles between oil changes
Since this is not injected, you can rule that out.
Lanier UNKNOWN | Answered on Feb 13, 2013
sc322 is an error with the copier's laser unit. You can pull the laser unit out and clean it up if there is toner on or in it, but more than likely either the polygon mirror motor or the laser unit as a whole assembly should be replaced.
Lanier UNKNOWN | Answered on Dec 14, 2012
SC546 is universal in Ricoh, Lanier and Savin. It is indicating that the machine does not see the fuser.
Lanier UNKNOWN | Answered on Nov 02, 2012
AMCAP VIDEO CAPTURE WILL NOT FUNCTIONPROPERLY
No I don't think so
Lanier UNKNOWN | Answered on Mar 05, 2011
I don't think the problem is on your firewire since it still charge your camera. I suspect your camera driver get fail. Please re move and reinstall the driver on your computer and get them paired again.
Regards, Jay
Lanier UNKNOWN | Answered on Mar 02, 2011
Hi, somehow the external key counter option for your copier got turned on. This option is typically used for coin-operated copiers such as those found in libraries. You can turn this option off by doing the following:
- Press the User Tools button - Select System Settings - Select Admin Tools - Select Key Counter Management - Choose Off, or de-select the full-color option if it is selected. - Exit out of User Tools
Now you should be able to copy normally!
Lanier UNKNOWN | Answered on Feb 12, 2011
You can delete contacts by going to the Address Book:
- Press the User Tools button - Select System Settings - Select Admin Tools - Select Address Book Management - Select the contact(s) you want to erase and choose the Delete option - Exit out of User Tools
Thanks for using FixYa! Please rate this solution if it was helpful to you, and let me know if you have any questions or it won't work.
Lanier UNKNOWN Logo
89 questions posted
Top Lanier Televison & Video Experts
gggg
Alun Cox
Are you a Lanier Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Lanier Televison & Video
Most Popular Question
ihave hiccups two days need method
  • Televison & Video
