You needb to drain the hydrolic fluid and then remove the suction tubethat comes from the right side of the engine and attaches to the hydrolic pump.Loosen the hose clamps and seperate the hose from the tube.Now go under the tractor and remove the brace that goes to the deck.Then go further under the tractor and take the last bolts out of the suction tube.Now you can remove the suction screen and clean it with some solvent and put it back in.Put your tractor back together,install a new hydrolic filter and top up the hydrolic oil,it should move.
Manual transmission with a power reverser.
No codes.
Runs fine but will not move forward or backward unless engine is reved to 2300rpm and then it only moves very slowly. However, front and rear hydrallic driven attachments work fine. It just does not move. like it is not in gear.
Hydralic screen is clean, all lubricants have been changed.
Rebuilding the power reverser unit, maybe it was leaking.
If you can give me more info i'm sure i can help.Is the tractor gear or hydro?Is there any codes?Does it stall when trying to move it?What have you tried so far?
