20 Most Recent John Deere 4020 Gas & Diesel Tractor Radiator Questions & Answers
2answers
Manual on maintenance and repair of diesel engine
To help you we really need to know what kind of generator,or at least the type and age of the motor.
1/3/2020 5:47:29 AM • John Deere 4020... • Answered on Jan 03, 2020
What do i torque the head bolts at?
John deere is proprietary. That information is not public.
9/2/2015 2:37:49 AM • John Deere 4020... • Answered on Sep 02, 2015
How can I restart my 4020 diesel after it ran out of diesel?
Crack open the line coming into the injection pump from the fuel pump (near the top of inj. pump, towards firewall). Pump the lever on fuel pump until fuel comes out of loosened line. Tighten line. Loosen at least two injector lines at injection pump head. Crank engine with starter until fuel pulses from loosened lines. Tighten lines. Crank engine again. Engine should begin firing on these cylinders first, followed by the remaining cylinders.
11/27/2014 12:14:47 PM • John Deere 4020... • Answered on Nov 27, 2014
Replace a fanbelt on john deere 4020 diesel tractor
Most older models had the adjustment on the alternator. loosen it and push it toward the engine. remove & replace the belt. Pull the alternator away from the engine until the pulley cannot be turned by hand due to the tension. Tighten the adjustment bolt to secure it. Don't overtighten the belt.
9/25/2014 8:05:54 PM • John Deere 4020... • Answered on Sep 25, 2014
How to sell JD 4020 that has no serial number
It must have had one. Usually stamped in many areas,check the frame ,under the hood and under the dash. If ITT was a recent purchase it may be stolen.
9/1/2014 10:53:42 AM • John Deere 4020... • Answered on Sep 01, 2014
0answers
0answers
0answers
0answers
2answers
I have a late 60's JD 4020 with 24v system.
check all grounds before further testing
5/30/2014 3:23:14 AM • John Deere 4020... • Answered on May 30, 2014
Out of Diesel
This particular JD engine has an individual fuel pump for each cylinder. The injectors, fuel lines, and pumps are not accessible from outside of the engine. There is a hand primer pump built into the top of the fuel filter. Start by removing the rubber outlet line from the filter base and pump the primer pump until fuel come out of the filter base outlet. Ounce fuel comes out of filter reconnect the line and continue pumping by hand until the pump button feels solid, then crank engine until it starts. This works better if a helper is available to operate the starter while continuing to pump the hand primer. This is normally all that is needed after running out of fuel. If fuel does not come out of fuel filter base there may foreign material inside of primer pump. Primer pump can be disassembled and cleaned. If fuel comes out of filter, primer pump become feels solid but engine does not start the fuel control rack inside of engine may be sticking in the off position. This may sometimes be overcome by clicking the key switch from off to on rapidly. If not you may have to have your dealer remove the governor cover to free the rack.
5/30/2014 3:09:16 AM • John Deere 4020... • Answered on May 30, 2014
John deer 4045 diesel engine timing diagram
and you can't just follow the fuel lines from pump why ?? cyl 1 is always one most forward
5/24/2014 2:19:00 AM • John Deere 4020... • Answered on May 24, 2014
2answers
I need to know the proper CCA rating for the
Since that tractor was made before they used CCA ratings could it be possible that no such official rating exists?
How about you use what ever size battery that will fit? If I recall correctly it takes two on each side of the tractor and they are rather long, tall and skinny - so much so that no normal battery would ever replace them physically. I'm thinking electrically just about any pickup battery would be a good CCA equivalent. Provided you are paying attention to the 12/24 volt issue on those dual battery JD setups like the 4020 had. If you have two six volt batteries and they work as one 12 volt then you can't use 12 volt batteries for your pickup, in other words.
In the real world the actual difference between a 500 CCA battery and an 800 CCA battery would be hard to tell until the temp got down around 20 below zero. THEN you might get your money's worth, and you might not. In my opinion and with my budget I won't go with a high capacity battery - they just cost too much more. I also don't live in Alaska, so I don't have to worry about it often enough to be cost effective. I get my warm fuzzy feelings from somewhere else...
If you are having troubles starting with normal rated batteries, you won't escape the same problems with higher capacity batteries. The troubles just cost more.
11/27/2013 9:14:36 AM • John Deere 4020... • Answered on Nov 27, 2013
John Deere 4020 Gas & Diesel Tractor Radiator Logo
124 questions posted
Top John Deere Garden Experts
john h
Sean Wright
Sean Wright
Jay Finke
Jay Finke
Are you a John Deere Garden Expert? Answer questions, earn points and help others
View Most Popular
John Deere Garden
  • John Deere Garden
Most Popular Question
old 4020
  • Garden
