I researched your watch online and on my initial search, I didn't find the instructions for your watch, however, you may wish to send the manufacturer a note requesting the instructions. Below is their email address.
I had the exact same problem with my watch, it wouldn't stop beeping or flashing and the reset would not work. I fixed the problem an hour ago by replacing the battery in the watch. hope this helps!!
Not a malfunction - just a dead battery. See the manual:
http://www.victorinox.com/medias/sys_master/timepieces_manuals/8800396705822/NightVision_II_ENGLISH.pdf
AC point is not located under the battery. It is at the edge of movement. Get an eyeglass with good magnification and you will find it.
Rate me, please.
Go on line under the watch name like www.bulova.com, there you can click on the service center and download instructions there once you find your particular watch brand.
This reset trick works with other Casio Alarm Chrono digital watches,
such as my old Model W-720, similar to your F91-W. After the new lithium coil cell is
installed and secured with the spring clip, the watch may show random
segments in the LCD display or may simply be blank. Insert a sewing
needle, paper clip, or blade of a small jeweler's screwdriver into the
hole on the back of the movement stamped "AC" (All Clear) to
momentarily connect the gold plated contact at the bottom of the hole
to the stainless steel battery clip. The battery clip in most such
Casio watches is connected to the "+" terminal of the coin cell. This
will reset the CMOS chip and it should start up with the watch
displaying 12:00 and the date at 1-1. Then, use the control buttons to
set the time and date in the normal fashion.
