20 Most Recent Tissot T-Touch T33159851 Wrist Watch Questions & Answers
5answers
How to reset tissot t-touch after battery replace?
AC point is not located under the battery. It is at the edge of movement. Get an eyeglass with good magnification and you will find it.
Rate me, please.
12/8/2022 11:49:28 PM • Tissot T-Touch... • Answered on Dec 08, 2022
11answers
"Tissot Touch" Touch screen failure
it all stems from the watch not actually being waterproof it's more water resistant than waterproof. The little indentations on the back that look like they are for a tool to unscrew it are actually holes i guess for the altimeter and meteo so it can sense pressure. Behind the back just behind the holes is a nylon gauze material and underneath this is a sensor slightly recessed and covered with some kind of waterproof substance. As far as i can see the problems lie here any water sweat or other foreign object than gets into this gauze will eventually will clog this gauze material which at first will affect the altimeter then the meteo. When the gauze has been clogged up severely i gets very dirty indeed which means when it gets wet it takes an age to dry out so if you wear it in the shower like i used to it will never dry out this causes the watch to malfunction quite severely. You can actually fix this problem yourself just get a very small flat screwdriver and lever the back off don't worry it's only a push fit and comes of easily you will see straight away a dirty damp smelly clogged up round piece of nylon gauze clean this up with a bit of WARM not boiling soapy water being careful not to disturb the pressure sensor and it's waterproof goo inside then dry it all and put it together
Hope this helps
Dom
England
9/15/2021 8:03:28 AM • Tissot T-Touch... • Answered on Sep 15, 2021
3answers
How do I reset my tissot t touch expert
Steps to Synchronize the Hands
  1. Press the centre pusher (T). The watch should beep once.
  2. Touch the centre of the touch-sensitive face until opt appears, in opt select 24H Cm (or 12H Fft or 24H Fft or 12H Cm) is shown in the digital LCD display.
  3. Press and hold the centre pusher (T) for approximately 5 seconds. The watch will beep once and then again, a second time, after 5 seconds have passed. After the second beep, the digital LCD display should read SYNCHRO. If not, return to step one.
  4. Press the upper pusher (+) to advance the hour hand until it is positioned exactly at 12:00. (PH press T button to to switch to minute hand adjust)
  5. Press the lower pusher (-) to advance the minute hand until it is also positioned exactly at 12:00.
  6. When both hands are aligned together and pointing directly at 12:00, press the centre pusher (T) to save the setting. The hands of the watch are now synchronized
11/5/2019 12:38:01 AM • Tissot T-Touch... • Answered on Nov 05, 2019
10answers
Hi, New battery in my T-Touch & reset, Thermo, Alt, Meteo problem
I'll be honest, I'm not sure. The easiest thing is to do with things like this are to send them in for a warranty repair. But I may be able to help you if this isn't an option. First, if you don't have the manual you can view it here. I've also included a breakout of the functions below.
If you reset the watch you have to set the touch mode and zone information before certain features will work:
  1. The Altimeter and compass with only display in touch mode and only for 30 seconds. Other options in touch mode display for 15 seconds.
  2. These will not display if you do not set the Hemisphere and Climate zone, instructions are on page 5/13 of the above manual
8/17/2016 7:00:14 PM • Tissot T-Touch... • Answered on Aug 17, 2016
2answers
The digital time display and
Hi,You can try to so the synchronization to match the digital time and the analog hands.here are the step by step procedure including visuals, click on the link.I hope this will resolve your issue.Thank you for choosing Fixya.
10/31/2014 8:57:13 PM • Tissot T-Touch... • Answered on Oct 31, 2014
How to replace the battery on tissot1853
You Can see the video in my blog how can change the battery from Tissot Sea Touch.Is all the same. www.watch4maker.com
10/6/2014 10:14:10 AM • Tissot T-Touch... • Answered on Oct 06, 2014
2answers
Tissot t-touch battery problem
If you take a jeweler's lupe near where the arrow is you will see the word "reset" in the plastic. There is a deep hole in the plastic with contacts below. That is the reset, and that is why you must use very sharp pointed tweezers to make contact with the back of the battery.I think if you do not have sharp tweezers, you can probably put a sewing pin down the hole, and then connect with a small screwdriver to the back of the battery
10/6/2014 9:22:15 AM • Tissot T-Touch... • Answered on Oct 06, 2014
Wrong airpressure reading in my Tissot Touch
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all TISSOT watch manuals.Rate me, please
9/25/2014 10:50:08 PM • Tissot T-Touch... • Answered on Sep 25, 2014
How do i set the time tissot t touch expert
Hi. As it would take a lot of time to write and draw all necessary figures right here, I would like to give you direct page address for all TISSOT TOUCH EXPERT settings. If the print is too small - use ZOOM tool to magnify it. Hope it will help. Follow this link: http://support.tissot.ch/usersmanual/141-en.pdf
9/23/2014 1:53:18 PM • Tissot T-Touch... • Answered on Sep 23, 2014
2answers
Hi guys,
The Tissot Touch watch is expected to need "SYNCHRONIZTION" periodically. (that is, to synchronize the digital and analog portions.) The Tissot manual tells how to do this. This manual came with your watch and is available online from the Tissot website.
good luck, Rodney
8/28/2014 12:10:18 PM • Tissot T-Touch... • Answered on Aug 28, 2014
Reset a t-touch expert
Shortcut battery with AC contact. AC can be found on the sides of watch movement(very tiny). You have to use pointed tweezers: one end on battery+, another on AC contact for three secsIf you take a jeweler's lupe near where the arrow is you will see the word "reset" in the plastic. There is a deep hole in the plastic with contacts below. That is the reset, and that is why you must use very sharp pointed tweezers to make contact with the back of the battery.I think if you do not have sharp tweezers, you can probably put a sewing pin down the hole, and then connect with a small screwdriver to the back of the battery
5/24/2014 2:27:14 AM • Tissot T-Touch... • Answered on May 24, 2014
2answers
The minute on T1 is one minute faster than on T2
hello,kindly pull out the crown at the middle of the crowns beside the tissot watch to set the time zone of the T2..you can kindly follow the instruction provided below in the site.
http://www.tissot.ch/virtualdata/usersmanual/123-en.pdf
www.tissot.ch/data/usersmanual/142-en.pdf
wish you good luck,
take care.
4/30/2013 1:34:32 AM • Tissot T-Touch... • Answered on Apr 30, 2013
Buzz sound the stuck
The Problem of this error is the battery level is down and the cant work all this functions.Please Keep the watch only for time until you change the battery
4/25/2013 10:11:18 AM • Tissot T-Touch... • Answered on Apr 25, 2013
3answers
Analogue hands don't correspode to digital clock
Sometimes a watch will be off center due to shock, dead battery etc. Symptoms are; hands don’t line up, digital and analog time doesn’t match, Compass function doesn’t have the hands exactly opposite etc. This can all be fixed. The Synchronization function can be used:
1. Activate Crystal
2. Tap center until you are the unit’s screen (12h or 24h, F ft or C m).
3. Push and hold (at least five seconds) the center crown
4. Watch will beep and word (SYNCHRO) will appear in the display.
5. Use the top + button to line up the minute hand right on the 12.
6. Use the bottom – button to line up the hour hand right on the 12.
7. When finished, press crown and you will go back to time.
11/4/2012 3:11:00 PM • Tissot T-Touch... • Answered on Nov 04, 2012
I own a Tissot chronograph
hello!
first of all you need to synchronize your watch
Advice on how to synchronise your watch:
To synchronise the seconds hand (3) with an official time signal (radio, TV, Internet), pull the crown into position III ; the seconds hand stops at this point.
At the tone, press the crown back into position I (and tighten it down if you have a model with a screwed crown).
Fast correction of the date* and day*
Important : Do not set the date* and/or the day* between 10 pm and 2 am (the movement is in the process of changing the date at these times).
Pull the crown into position II and turn it clockwise until your watch display the correct date (4) and turn it anticlockwise to change the day setting (5)*. During this operation, your watch will continue to function normally, so you will not need to alter the time.
6/5/2012 1:25:23 PM • Tissot T-Touch... • Answered on Jun 05, 2012
3answers
Touch screen is not working
==== http://www.voguecatch.com ==== ====accept credit card and paypal
Cheap Nike air Jordan shoes33$,Air Force 1 33$, Nike dunks SB shoe,Nike Shox shoe. Wholesale Cheap Nike shoes with discount jersey, High quality T-shirts,ED hardy t-shirts,ED Hardy hoodies,ED hardy shoes,ED hardy Jeans,Evisu shoes,GUCCI shoes,LV Handbag,Chanel Handbag......welcome to ==== http://www.voguecatch.com ====
Nike shox(R4,NZ,OZ,TL1,TL2,TL3) $35
Handbags(Coach lv fendi d&g) $35
Tshirts (Polo ,ed hardy,lacoste) $13
Jean(True Religion,ed hardy,coogi) $30
Sunglasses(Oakey,coach,gucci,Armaini) $15
New era cap $16
Bikini (Ed hardy,polo) $18
1/13/2012 2:54:39 AM • Tissot T-Touch... • Answered on Jan 13, 2012
4answers
Thermo shows 91.7c, Meteo shows just hpa and
same question here, but it happens to me after a dead battery replacement, although the temp on my watch indicate 78.0 c, another sympthons are the same
10/31/2011 4:28:10 PM • Tissot T-Touch... • Answered on Oct 31, 2011
2answers
Hour hand does not match digital time
Hi, activate the touch screen, touch the middle of the screen 3 times slowly until you see the OPT in the LCD. press the middle big button on the side of the watch once until you see the 24H screen, then hold down the same side middle button for 5 seconds, the display will then say SYNCRO.
You first move the hour hand with the top and bottom side buttons to 12 touch the middle of your screen to set then move the minute hand to 12 as straight as you can, then press the middle of the screen to set to exact digital time. Thanks Mark ;-)
8/19/2011 1:22:22 AM • Tissot T-Touch... • Answered on Aug 19, 2011
Watch hour and minute hands are not lined up at 12 o'clock
Take the back off, then slip the works out of the case. move the hands to line up at 12.. hope this helps..
7/7/2011 11:37:29 PM • Tissot T-Touch... • Answered on Jul 07, 2011
Tissot T-Touch T33159851 Wrist Watch Logo
127 questions posted
Top Tissot Watches Experts
Ngoro
john h
k24674
Are you a Tissot Watch Expert? Answer questions, earn points and help others
View Most Popular
T Tissot
  • T Tissot
Most Popular Question
reset tissot t touch after battery
  • Watches
