20 Most Recent Casio Sea-Pathfinder SPF40-1V Wrist Watch Questions & Answers
We are not a sales site or a seller site. Please use eBay. Thanks
Casio... | Answered on Dec 05, 2016
You can download it from Casio website i think
Or contact the service center for help
electronics wholesale
This watch must be returned to Casio service center for servicing, pressure test and complete tune-up.
Casio... | Answered on Mar 04, 2015
Around the outer edge of the watch there will be an indention. Pry open with a small screwdriver. Your internal compartment should be right there.
Casio... | Answered on Dec 25, 2014
Harbor Freight sells a low cost watch wrench but in a Robinson Crusoe situation you can CAREFULLY use square nosed needle nose pliers(Lowes or The Home Depot won't object if you try out one of theirs); hold watch in wash cloth to protect your hand, put the square blades in the watch back indentations and slowly turn with maximum pressure, after it opens use a quality Japan Maxell SR621W silver oxide, do NOT use a China alkaline version as they leak and have less run time. Use a Q-Tip with light Vaseline around the sealing edges when reassembling. Sincerely batteryBob
Casio... | Answered on Nov 19, 2014
Yes Where the scew holes are for the back plate you will see two smaller holes located outside the seal groove. The spring goes in the left one.
Casio... | Answered on Apr 08, 2014
Note how the buttons around the outside edge of the watch match up to the compass directions on the outer ring of the watch face. Use the butttons on the NW, NE, SE, and SW positions.
  1. To enter time setting mode, press and hold NW until the Seconds start to flash. (You can exit time setting mode at any point by pressing NW twice)
  2. Release NW and press SE to reset the Seconds to 00.
  3. Press SW and the Hours will start to flash.
  4. Set the hour by pressing NE (down) or SE (up) Press the lower button to move up and the upper button to move down.
  5. When the hour is correct, press SW and the Minutes will flash.
  6. Set the minutes by pressing NE (down) or SE (up)
  7. When the minurtes are correct, press SW and the 12/24hr setting will flash.
  8. Switch between 12hr mode and 24 hour mode by pressing SE.
  9. Press SW and the Year will flash.
  10. Set the year by pressing NE (down) or SE (up)
  11. When the year is correct, press SW and the Month will flash.
  12. Set the month by pressing NE (down) or SE (up)
  13. When the month is correct, press SW and the Day will flash.
  14. Set the day by pressing NE (down) or SE )
  15. When the day is correct, press SW and the seconds will flash again.
  16. Exit time setting mode by pressing NW twice.
This is a complex watch. You can download a manual here http://www.casio.com/products/archive/Watches/PRO_TREK/SPF40-1V/
Casio... | Answered on Apr 03, 2014
here is a video that will show you enjoy
Casio... | Answered on Apr 17, 2013
I have done the same , you are not alone and about to try to fix it.has your compass stopped working as with mine
Casio... | Answered on Feb 15, 2013
Casio Sea-Pathfinder SPF40-1V Wrist Watch Logo
89 questions posted
Top Casio Watches Experts
Arturs Kalnins
Arturs Kalnins
k24674
Are you a Casio Watch Expert? Answer questions, earn points and help others
View Most Popular
Pathfinder Casio
  • Pathfinder Casio
Most Popular Question
casio spf40 2273 module went crazy move
  • Watches
