20 Most Recent Casio F91W-1 Wrist Watch Questions & Answers
Casio F91-W how do I reset the display?
A bit late but... There are connections on the PCB that you need to short to ground. Top right of the screen resets the watch. Middle one resets the screen. When you have assembled the watch you can see the holes on the white plastic part.
9/28/2021 10:46:21 AM • Casio F91W-1... • Answered on Sep 28, 2021
2answers
Please help me to replace battery on my casio F-91W
This reset trick works with other Casio Alarm Chrono digital watches, such as my old Model W-720, similar to your F91-W. After the new lithium coil cell is installed and secured with the spring clip, the watch may show random segments in the LCD display or may simply be blank. Insert a sewing needle, paper clip, or blade of a small jeweler's screwdriver into the hole on the back of the movement stamped "AC" (All Clear) to momentarily connect the gold plated contact at the bottom of the hole to the stainless steel battery clip. The battery clip in most such Casio watches is connected to the "+" terminal of the coin cell. This will reset the CMOS chip and it should start up with the watch displaying 12:00 and the date at 1-1. Then, use the control buttons to set the time and date in the normal fashion.
11/14/2018 7:36:35 PM • Casio F91W-1... • Answered on Nov 14, 2018
Turn off alarm
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all CASIO watch manuals.Rate me, please
9/28/2017 8:58:50 AM • Casio F91W-1... • Answered on Sep 28, 2017
My F91W-1 has water condensation under the clear display. Even after getting rid of it with silica gel, water still condenses inside. Watch works fine. Is there a permanent fix for it?
Water vapor is getting inside watch and condensing. Need to address any and all seals to make sure that they are air/water tight.
6/13/2016 8:29:04 PM • Casio F91W-1... • Answered on Jun 13, 2016
3answers
How can you make a "Casio f-91w" watch not beep
Push the lower left button. The alarm time is showing.
Press the lower right button and it will cycle the hourly beep and alarm on/off.
Press the lower left button to exit when the setting are what you want.
8/10/2014 10:19:49 AM • Casio F91W-1... • Answered on Aug 10, 2014
0answers
0answers
manual
manual
24 hour time
With the time showing, press the lower right button. This switches between 24 hr and 12 hr every time you press the button.
10/22/2013 2:06:37 AM • Casio F91W-1... • Answered on Oct 22, 2013
2answers
How to change the time on my Casio F91W watch?
first you push the bottem left butten three tmes than push the top left corner to move threw the numbers than use the bottem right butten to change it
11/25/2011 5:50:02 AM • Casio F91W-1... • Answered on Nov 25, 2011
Turn off alarm
you need to look at the user manual that
you can download a soft version of the user manual on below link. .when you open the link just write the 4 digits code on the back side and click searched on the URL below
Hope this helps! Take care and please Remember to rate/vote and
give me 4 Thumbs Up for me to continue for Helping out the Community :)
Thanks
CASIO Watch User Manual Archives
http://world.casio.com/wat/download/en/manual/
Use this page to download a copy of CASIO watch manuals in PDF format.
To download a PDF file, enter the four-digit (or three-digit) module number marked on the back cover of your watch.
10/9/2011 5:58:09 PM • Casio F91W-1... • Answered on Oct 09, 2011
How do you turn the
ho do i set my f-91w
8/16/2011 3:27:33 PM • Casio F91W-1... • Answered on Aug 16, 2011
0answers
Lost manual, need to set
Hi,here is the user manual..
soft version of the user manual pls visit the URL below..
Hope this helps! Take care and please Remember to rate/vote and give me
Thanks
7/2/2011 7:09:49 AM • Casio F91W-1... • Answered on Jul 02, 2011
Casio F91W-1 Wrist Watch Logo
48 questions posted
Top Casio Watches Experts
k24674
Robert
ZJ Limited
ZJ Limited
Are you a Casio Watch Expert? Answer questions, earn points and help others
View Most Popular
Casio Watches
  • Casio Watches
Most Popular Question
turn off alarm
  • Watches
