My Acer Aspire laptop keeps shutting down for no reason, not a heat problem, does it randomly, after it's on for 1 minute, or 2 hours, or 10. Seems to usually shut down upon movement. Could something be loose? It's over 2 years old and used ALOT-logged in over 2000 hours last year. Has a Pentium processor.
ALSO-recently cleaned and defragged, somehow lost Firefox, deleted and re-installed, all is ok with that-related?
Start in safe mode and see if it does it still, if not its a program related error and you can reinstall op sys. if it does than i would wage it is bad memory or fan
lot's of possibilities, Either your laptop has Virus, or the processor over heating, means it will probably need to di-assemble and replaced heating compound.. called thermal paste..
it may be one of the causes, but the main reason for it is the power supply keeps on fluctuating. You may call Acer for a possible replacement for it..
If the laptop shuts down after a period and won't boot up again until the laptop has cooled down, then the laptop has a thermal overload problem. For instructions to fix this problem, please click on this link :-
Normal
0
http://www.fixya.com/support/r5959377-overheating_computer
1- Scanning computer to eliminate malwares, spywares and the viruses from your laptop.
2- Repairing and cleaning Windows registry.
These two tips are found to be very helpful to fix the laptop shutdown problem. Almost all the computer users surf internet which could result in viruses attacking your system. Some of these infections are really pesky and cause the machines to shutdown randomly.
The registry errors, however, are the internal errors and can become a cause of system crashes and freezes. The registry keys shall be in good health to keep a system perfect.
When I noticed my laptop keeps shutting down everytime, I tested the Intel Software Partner, RegInOut to fix the random shutdown problem with my laptop.
increase ur ram
It sounds like someone has suggested that overheating may have caused the random shutdowns (which is quite plausible). There are a few tools that can diagnose what is happening:
Temperature: I use SpeedFan (http://www.filehippo.com/download_speedfan/) to discover the temperature of my cpu. My Acer 5630 is usually doing 50 to 60 degrees. Anything higher than that could cause the random shutdowns (I've seen it happen on other laptops). If you download this program, don't muck around with the settings (as it would advise you not to anyway), just look at the temperature readings (eg. core 1 core 2)
Treatment of overheating would be to find the offending software and manage it or remove it. If it is not software at fault, then it may be that there is too much dust covering the ventilation (Your acer may be old and you may hear your fan increasing speed and the performance struggle sometimes). I opened up my one and found dust build up from the radiator all the way to the fan! (it was like around 1cm thick in some places, i wish i took a picture)
Another reason for random shutdowns is the integrity of the power switch or the lid sensor. My computer got rained on once and randomly shut down. It took a while of cleaning it with Circuit board cleaner from Repco (I had to open the panel that covered the power button and spray it). It got better everytime I cleaned it and now it reliably stays on (actually it randomly turns on now haha)
