Ext hard drives, once enabled, should be seen like any other logical drive, on the system. this one appears to have an issue with the usb connector. Go to control panel, system, hardware profiles and see if there are any of the items with a yellow ? mark on them, and let us know your results.
Testimonial: "yes you are right there is a item that is yellow. VIA bus master IDE driver. I clicked on it to update the drive but it can't find what is needed. "
Most USB devices do not work when connected to a computer as the computer boots up (unless the BIOS allows this function).
Boot up the computer first and then insert the USB device/hard drive.
If you need to remove a USB device when the computer is running then click on Safely Remove Hardware - click on that device and ONLY REMOVE the device when advised to do so. Failure to do this will eventually cause the device to fail.
I am Running a PC with Windows XP
care to share the operating system with us?
