Try putting the flash drive in another computer and if it does the same thing kiss the flash drive goodbye and throw it away.
If it works fine in another computer the problem exists on your USB buss and likely will do the same with any USB device. If this is the case you could try reloading all the USB drivers. If this doesn't help you probably have a short in the USB buss and will have to take it to a local repair facility or contact the PC manufacturer about repair options.
I had the same problem. Laptop rebooting any time I stuck a USB stick
in any of the two ports at the back. Got some ideas from here. Had a
spare 4 port USB PCI device and put this in so that I could copy if
possible some important files to a USB stick before perhaps rebuilding.
It installed fine and all the USB sticks worked fine in it. Copied the
files over and that accomplished tried the USB sticks back in the two
back ports again. Now they both work perfect with or with the PCI card
inserted.
