20 Most Recent PNY 4GB USB 2.0 Flash Drive - Grey/Black Questions & Answers
PNY is not working
the computer is not seeing it properly un plug,then refit ,are the contacts clean,
10/13/2018 1:27:03 PM • PNY 4GB USB 2.0... • Answered on Oct 13, 2018
2answers
I had purchased 4 GB and 2GB(2nos.) usb pen drive
Best to contact your dealer.
12/13/2016 8:08:42 PM • PNY 4GB USB 2.0... • Answered on Dec 13, 2016
Pen drive not working what I do
If the pen drive is not recognize in any PC, that's it, it's damage and there is no way to recover anything from the pend drive, sorry. Being there.
7/10/2016 6:47:37 PM • PNY 4GB USB 2.0... • Answered on Jul 10, 2016
Remove the WORM/LNK.Lodbak.Gen virus from my flash and every folder is hiden
Hello,You need go to www.malwarebytes.com and do the free download and scan everything.
9/28/2015 7:57:50 PM • PNY 4GB USB 2.0... • Answered on Sep 28, 2015
I can't delete pictures from pny performance 4 gb thumb drive.
it may have viruses so you should format this flash NTFS or FAT32
3/9/2015 7:10:27 AM • PNY 4GB USB 2.0... • Answered on Mar 09, 2015
How do u put music and videos on a PNY 8gflashdrive memory stick
Copy and paste or drag and drop to the stick.
8/17/2014 4:00:38 AM • PNY 4GB USB 2.0... • Answered on Aug 17, 2014
Unable to save files
this flash is write protected by a pass word
8/4/2014 8:03:55 AM • PNY 4GB USB 2.0... • Answered on Aug 04, 2014
How can i format writeprotected pendrive
To disable the write protection:
    1.From the Start menu, click "Run", type "regedit", and press <Enter> or click <OK>. 2.Navigate to HKEY_LOCAL_MACHINE > SYSTEM > CurrentControlSet > Control > StorageDevicePolicies. 3.Double click on "WriteProtect" and change the value to 0 (WriteProtect = 0 for disabled; 1 for enabled). 4.Close the registry editor and restart Windows. 5.After Windows starts, test writing to your USB drive. Important Note: Serious problems might occur if you modify the Windows registry incorrectly. **PLEASE** make sure that you follow these steps *exactly* and *carefully*. For added protection, back up the registry before you modify it in case you have trouble so it can be restored. For more information about how to back up and restore the registry, follow the steps as in the KB Article: http://support.microsoft.com/kb/322756/
4/30/2014 12:38:17 AM • PNY 4GB USB 2.0... • Answered on Apr 30, 2014
2answers
Write protected PNY 4GB USB
Go to Start Click Right mouse button on Computer Click on Manage Click on Disk Management In the Right Panel of the drive you wish to fix Click Delete Volume When Volume is deleted Click Create Volume Follow the steps For small drives use Fat32 not NTFS NTFS is not portable between XP and Win 7 You may also have a virus.
4/14/2014 2:55:29 AM • PNY 4GB USB 2.0... • Answered on Apr 14, 2014
2answers
Cannot format flash drive.... receive message
Usually there is a small switch or colored slide which flips between write protected and writable. If there is no switch it may be the software that is on the drive is preventing the format, if this is the case you may need to use a boot disk like Hiren's boot Cd to format it while not booted into Windows.
4/14/2014 2:46:03 AM • PNY 4GB USB 2.0... • Answered on Apr 14, 2014
Writeprotected
Plug the flash drive in your computer. Then go to the Cmd Prompt, RunAs Administrator, Then type Diskpart > To list all the available Disks, type List Disks. You will see all the drives listed with a number ID. So the flashdrive might be Disk 3, or whatever. Now type Select Disk # (whatever the flashdrive # is) Now type Attributes clear readonly. Now type Exit, to leave the diskpart applet That should do it.
4/6/2014 8:31:47 AM • PNY 4GB USB 2.0... • Answered on Apr 06, 2014
3answers
How can format usb
Hi there !
Just connect your usb flash disc into a usb port of your computer. Then right click mouse and you will see the FORMAT command there. Just run it and it will format your USB flash disc.
3/19/2014 9:40:15 AM • PNY 4GB USB 2.0... • Answered on Mar 19, 2014
2answers
ACCIDENTY TRASHED 2 EXTREMELY IMPORTANT
When you deleted files and folders on your flash drive, they don't goes to trash. Deleting won't make them erase permanently. Those deleted files and folders are still stored on your flash drive, they're just invisible or inaccessible. You can recover deleted files from flash drive with flash drive recovery software. I had succeed with Tenorshare Data Recovery.Anyway, you can download it and scan your flash drive for free to preview whether you can recover your files. It will show you the file name, type, date and size of your files and thumbnails for your pictures that it found on your drive.Get it from http://www.any-data-recovery.com/product/datarecoverystandard.htm
8/6/2013 2:30:06 AM • PNY 4GB USB 2.0... • Answered on Aug 06, 2013
Unlock
memory card kagaon?
7/15/2013 10:38:20 AM • PNY 4GB USB 2.0... • Answered on Jul 15, 2013
Repair
It may be broken, but I've found that you can get a repair for a non-appearing pen drive by using the wonderful software called photorec bundled in the testdisk software. (http://www.cgsecurity.org/wiki/TestDisk_Download)
6/13/2013 4:23:21 PM • PNY 4GB USB 2.0... • Answered on Jun 13, 2013
How do i remove write protection from usb pen drive
You have to be the computers administrator to change any values on any hard drive on your computer click start control panel user accounts on the users tab click the name of the computer administrator you must have full control click start click to open on my computer you should see your usb drive could be E: or something right click select properties there will be an array of options select the sharing tab option then advanced sharing make sure you have a tick in the share this folder box then click permissions make sure you have all 3 boxes ticked full control changes and read in windows 7 click start control panel user accounts click on the administrators account if you have made one or you will have to create one in windows XP click start right click on my computer select open Right click the icon of your usb drive (It should be E:/ or something) Click Properties in the menu that comes up Click the Sharing tab Click permissions And finally, click Allow next to Full Control. if you need more help with this post a reply Hope this helps.
1/11/2013 11:18:15 PM • PNY 4GB USB 2.0... • Answered on Jan 11, 2013
Decrypt files on a mac
Maybe there is a version of the software you used to encrypt that is compatible with mac ?
12/31/2012 7:19:20 AM • PNY 4GB USB 2.0... • Answered on Dec 31, 2012
PNY 4GB USB 2.0 Flash Drive - Grey/Black Logo
223 questions posted
Top PNY Electronics - Others Experts
Grand Canyon Tech
Grand Canyon Tech
Steve Sweetleaf
Steve Sweetleaf
Are you a PNY Electronics - Other Expert? Answer questions, earn points and help others
View Most Popular
  • PNY Electronics - Others
Most Popular Question
re using flash drive
  • Electronics - Others
