Honda Mmd 5000 Watt Electric Start Generator W/  Engine Ngk 6000HE Logo
Posted on Nov 17, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
No power at outlets
I own a Honda EM5000 but I cant seem to get any power out at the outlets. Any troubleshooting techniques I can use? Thank You
Anonymous
Level 3:
  • Master 317 Answers
  • Posted on Nov 17, 2009
Anonymous
Master
Level 3:
Answers
317
Questions
Helped
98986
Points
1237
There are fuses located on the gen..check those
2helpful
Honda EM6500S Generator. What is the inlet valve and exhaust valve and cylinder head settings on the EM6500LPG Generator please?
Question edited for a lot more clarity.
Question moved to model category.
Page 93 of the manual refers
Owner's Manual - GENERATOR EM5000SX/EM6500SX
Honda https://cdn.powerequipment.honda.com > manuals PDF This owner's manual is considered a permanent part of the generator and should remain with the generator if resold. The information and specifications included ...
Honda Small Engine Intake & Exhaust Valve Clearances
Steve's Small Engine Saloon https://www.stevessmallenginesaloon.com > hon... PDF Model Series. Intake Valve Clearance. Exhaust Valve Clearance. GX640. 0.10-0.14mm ( 0.004-0.006in ). 0.18-0.22mm ( 0.007-0.009in ). GX100. 0.15 +/- 0.04mm.
Honda EM5000 generator. It won't start after running out of fuel. Looks like it has an EFI system?
Question edited for clarity (make model (what it is)'.
Question moved from Honda Cars.
I can't find any details confirming it is EFI or not
https://powerequipment.honda.com/generators/models/em5000
How long was the fuel pump running empty? They burn out pretty fast as the fuel provides cooling and lubrication. Apparently there is a service manual for them. It may be that the fuel just needs bleeding through to the injectors.
Is it within warranty?
" 3 year residential and commercial warranty "
Everstar mpm2-10cr-bb6 will not reset on power cord. light on reset doesn't light. seems like no power is getting to the unit.
Check the outlet that the unit is plugged into, to be sure that it is in fact, working. The circuit breaker in your home's circuit breaker panel for that outlet, may have tripped. Also, the outlet may have interior damage or a loose wire connection. If the unit seems not to be getting power, one of the above is the problem. Try plugging the unit into another outlet in a different room.
Hope this helps you troubleshoot and solve the problem.
I have a Dell 2007WFPb 20`` Widescreen TFT Flat Panel Monitor. I cant seem to power up. What is the problem here?
Here is one of the simple solution to your issue.
I suggest your try a different outlet, if your using a strip, try connecting it directly to the power outlet. Also most of the monitor has the same power cable as the computer, try swapping the power cable and make sure only the power cable is connected to test the monitor. If still doesnt power on, call Dell and have it replaced if still has a warranty if not, repalce the monitor.
I hope this resolve your issue.
Thank you for choosing fixya
Where do you remove the Ground Neutral bond on a EU6500is generator? I need to do this to hook it up to a transfer switch as per Service Bulletin #20.
Page 39 of the current owners manual for the both EU6500 and the EM5000 generators indicate that there is not a neutral ground bond on these units.
Per the wiring diagram, the ground pin on the outlets is connected to the frame ground of the generators (on both generators). To have grounded electrical service, a bond wire would connect the generator frame to the ground terminal on the transfer switch. The ground system from the breaker / distribution box (usually to a ground rod) then serves as the electrical ground for the generator, as well as the balance of the rest of the system, satisfying NEC requirements.
See Page 39 in both manuals:
EU6500 EM5000
"The system ground is not connected to the AC neutral
wire. If the generator is tested with a receptacle tester, it will not show the same ground circuit condition as for a home receptacle."
Where is the knock sensor located at on my honda odyssey 1999? i cant find it someone help
It is in the inner V of the V-6 at least on my 2000 with 3.5 liter engine. It is towards the front passenger side of the engine. It is located behind the power steering pump and it seems like their are two forum listed techniques for replacement - moving the pump or more likely removing the intake manifold and front fuel rails. Many times it seems to be rodent damage to a wire harness, apparently soy based, rather than the sensor itself. Honda has a new part number to prevent re-eating!
1helpful
2009 Honda Accord Coupe power outlet problem
yeah you can check your fuses on the driver side under the dash board, you will find one of them blowed.
Top Honda Electrical Supplies Experts
vince
Paul Carew
Are you a Honda Electrical Supply Expert? Answer questions, earn points and help others
