20 Most Recent Danby DPAC8020 Air Conditioner Questions & Answers
3answers
Everstar portable ac fills the overflow water
Air conditioners cause the moisture in the air to condense on the evaporator coil. The water that is created needs to have somewhere to drain. If the unit is in a humid environment, it will create allot of condensation. This kind of operation is not uncommon.
7/22/2022 1:23:02 PM • Danby DPAC8020... • Answered on Jul 22, 2022
2answers
Danby Air Conditioner
I have the same problem with my Danby AC unit...every 5-20 seconds it makes a god awful clicking noise...Make me wanna cry
7/4/2022 2:43:31 AM • Danby DPAC8020... • Answered on Jul 04, 2022
My portable air conditioner stopped working. It
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool…
Air Conditioner Trouble - Review the Possibilities
heatman101
11/23/2018 10:59:01 AM • Danby DPAC8020... • Answered on Nov 23, 2018
2answers
Everstar Model MPK-10CR, What does flashing P2 mean?
p2 means the bottom pan is full, you need to drain the bottom, small valve on the back bottom in the middle
8/11/2018 2:39:57 AM • Danby DPAC8020... • Answered on Aug 11, 2018
Danby DPAC8399 Portable Air Conditioner no Cool air
You possibly might have a bad switch or have a dirty ac unit.Try 1st turning off the unit and cleaning the inside ...
7/5/2018 7:39:13 PM • Danby DPAC8020... • Answered on Jul 05, 2018
2answers
I have a Diplomat portable
I was having the same problem as the OP, thanks everyone who replied to this! I didn't know what to do when on a 40°C day my AC turned off and P1 came on the display, I just needed to empty the water ! It's actually a pretty good safety feature !
Cheers!
7/4/2018 12:56:07 PM • Danby DPAC8020... • Answered on Jul 04, 2018
3answers
P1 error on everstar mpk10cr and comprossor wont turn
On the MPK-10CR, this code shows up (for me) when either the bucket for evaporation collection isn't in the compartment, or it isn't seated properly. Try re-seating it a few times until you hear the A/C kick in.
You can get the manual on the link below if you need it.
http://www.supportuscenter.com/documents/MPK_Manual.pdf
Good luck
5/25/2016 2:39:25 AM • Danby DPAC8020... • Answered on May 25, 2016
I need to find a owners manual for an everstar portable air
Try going to the Danby website. They have owners manuals for many items that have been discontinued. Check to make sure you have the right model number as there is a white printed tag that they use as well as the one printed on the metal back. Sometimes they aren't the same. (Why, I don't know.) Otherwise, Google the number.
4/3/2016 11:55:13 PM • Danby DPAC8020... • Answered on Apr 03, 2016
2answers
I have a dandy portable
The best place to start is the manufacturer, Danby. For parts not covered under warranty call
800-496-6049. In your unit is still under warranty call 800-263-2629.
Hope this helped you. Please let me know. Thanks.
8/15/2015 5:33:15 PM • Danby DPAC8020... • Answered on Aug 15, 2015
2answers
Everstar mpm08cr bb4 will cool briefly then briefly blow hot air
check your filter and replace,, and that dont do it,, you need to clean coils,, and if that dont work it may be low in gas,, hope this help you
8/7/2015 2:21:57 AM • Danby DPAC8020... • Answered on Aug 07, 2015
3answers
My Everstar MPK-10CR portable 10,000 BTU's is blinkink P1 all tim
Just got one of these used, and also got the P1 error. Took the case off (which just involved a lot of Phillips head screwdriver turning), and found a sensor switch just to the left of the drain box inside the case. If I press on the sensor switch, the P1 error goes away, but then I get a blinking dot on the LCD display. Pressed the power button after that (while still holding the sensor switch) and it started working again. It looks like it was super-glued either originally or by a previous owner. Just needed to be re-positioned towards the top left corner where the drain pan sits. Just be careful when removing the case to not disconnect any of the wires going to the LCD display.
8/5/2014 5:45:14 AM • Danby DPAC8020... • Answered on Aug 05, 2014
Danby DPAC8020 Air Conditioner Logo
223 questions posted
Top Danby Heating & Cooling Experts
ZJ Limited
ZJ Limited
john h
Are you a Danby Heating and Cooling Expert? Answer questions, earn points and help others
View Most Popular
  • Danby Heating & Cooling
Most Popular Question
everstar mpk 10cr portable 10 000 btus
  • Heating & Cooling
