20 Most Recent
Danby DPAC12031 Air Conditioner Questions & Answers
Not cooling room
Assuming the unit is 'cooling' but not cooling it 'well,' I would think the unit is too small.
NOTE: 2000 Btu for every 100 sq ft of cooling space if the room is well insulated. If not - then 2000 btu for every 66 sq ft.
For example - a 12000 btu AC unit should cool 600 sq feet of cooling space if well insulated.
or
400 sq feet if not well insulated.
hope this has helped.
I have a DPAC 13009
From your description, I would have to agree with you on the pieces being from a broken fan. The good news is, that your model has a 24 month in home service warranty, so the parts and labor to repair are covered. But, the real key is having a Proof of Purchase. Armed with that, you're good to go.
Contact Danby Consumer Support 1-800-263-2629, to file a Warranty Claim.
I hope this helped you and thanks for choosing FixYa.
The plastic cover that goes
The vent termination is simulair to a dryer vent termination. Take the broken with you and visit any home center or hardware store, and I am sure you will be able to find an adequate replacement.
My Split system Centrex CTAR60GW
Dear friend. the timer problem is very common. Remove battery from remote and also remove power to unit. Again plug power on unit and start with remote and try to cancel the timer on and off. Press set.
And also cool setting must be minimum 3 degree less than room temperature. Helpful advise?
My Danby Premiere DPAC 13009 is leaking water
Water is collected from cooling mode,
not just dehumidifier mode. It does not always evaporate into the
exhaust stream due to design limitations.
Of course the water should never leak
even on the hottest day. Two suggestions:
Try removing the hose and attaching the
external tank to see if it has any effect. Otherwise, you'll need to
locate the exact source of the leak.
I am purchasing the DPAC 13009 Danby 2009 portable A/C, but....
Mae; I'm sorry to hear another good deal went bad. Door to door wholesale is a way to sell items that can't be sold in stores.. If you take a picture of what the hose connecta to and send it to me, I'll see what I can do. Explain the purpose of this hose andthe measurement of the connector outside diameter. The picture will say alot, I would appreciate it. e-mail the picture to
[email protected] and we'll figure out something.
The unit only goes down to 16 celcies
Its quite a low celcius setting A/C units are set around 21 deg for comfort. I would be uncomfortable at 16 deg c you really just want comfort cooling.
DPAC 13009 portable air conditioning problem
Remove your remote control on the unit, follow the manual step by step. First, do the emergency on/off button, then operate the air conditioning using the remote control, follow the procedure of your manual.You may notice a clicking sound of your remote control. The yellow/green color of your emegency on/off button will turn to blue. Do not put it back your remote control on the unit because he may sense the temperature of the vent, and your air conditioning will not stay on, it will shut off every five minutes. Your problem is solve.
Regards,
Cesar
