RE: CANON A720 digital camera
The top portion of the plastic "catch" for the battery compartment door has broken free (probably from the constant pressure of the springs pushing the batteries against. Is this a material/design flaw? Will Canon fix the problem to correct what amounts to a defect. Camera has not been dropped or damaged.
SOURCE: Broken battery compartment door switch
The switch is a micro switch that is depressed(and not sad :)) by a plastic tag moulded on the battery cover. Once the cover is moved into position and closed, the tag presses on the micro switch closing the switch and thus removing the error message. As with any switch, a switch is simply open or closed, Open = high resistance or O/L, while closed = 0 ohms reistance. You can use a small wire to overcome the switch by soldering the wire to both tags of the switch so it is permenantly 0 ohms. This will send a message to the microprocessor that cover is closed and camera ready for use. Hope this helps.
Twitcha
SOURCE: Broken battery retainer clip (red) on Olympus C-7000 Camera
You may want to call Olympus Customer Service and see if you can order this part from their parts department. Their telephone number is 800-622-6372 option 2 and then option 3.
SOURCE: The battery door hook which is situated on the
If you have all of the pieces, you can use crazy glue to make the repair, otherwise take your camera to any camera shop where they will have access to whatever broken components need to be replaced. Regards, Joe
Testimonial: "Thanks mate. Reply much valued I have the tiny broken part. Will try crazy glue and reinforce with a piece of tiny metal strip as well "
