Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White Logo
Posted on Nov 02, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Number and temperature decals washed off my stove. I can't even remember right now if its a hotpoint or a frigidaire~ that washed away too!
  • John Ivey Nov 07, 2017
    Check out StoveDecals.com; USA based and they make custom replacement stove decals for your stove model.
Anonymous
Level 3:
President:
  • Master 1,304 Answers
  • Posted on Nov 02, 2009
Anonymous
Master
Level 3:
President:
Answers
1304
Questions
0
Helped
367586
Points
3700
You can find your model number behind the drawer
sometimes it is on the back side of the drawer front
hope this helps
but to asssure you both have repalceable mylar covers
John Ronn
Level 1:
New Friend:
Problem Solver:
  • Contributor 9 Answers
  • Posted on Dec 29, 2018
John Ronn
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
9
Questions
0
Helped
16432
Points
18
Check out www.stovedecals.com - they can provide replacement stove decals for most major models and brands! They operate in Florida and manufacture the decals in the USA!
George gray
Level 2:
Sergeant:
  • Expert 120 Answers
  • Posted on Nov 07, 2017
George gray
Expert
Level 2:
Sergeant:
Answers
120
Questions
0
Helped
35032
Points
549
You can go on your computer type in Appliance parts Pros dot-com they should help you there
Lisa claire
Level 1:
New Friend:
Problem Solver:
  • Contributor 8 Answers
  • Posted on Aug 23, 2015
Lisa claire
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
8
Questions
0
Helped
17916
Points
16
You can buy new decals for GE cooktops and stoves from Ovenlettering based in the UK.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Dec 19, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
3767
Points
The burner temperature decals are washing off our GE True Temp (model # JSP42SK4SS) range. I can't find just the decals....just the entire face plate assembly at about 220.00. Any ideas?
1helpful
Oven temperature will not cycle
How To Fix Oven With Little or No Heat When Baking ...
www.partselect.com/Repair/Range-Stove-Oven/No-Heat-When-Baking/
Repairing a range, oven, or stove can seem like a big task, but our ... Most electric ovens use both the bake element and the broil element in a bake cycle, with the bake... If the bake element isn't working, the oven may not reach the set temperature or ...If the element appears to look normal, then turn the oven on to a bake ...
Electric Stove Repair ' Electric Oven Repair Manual ...
www.appliancerepair.net/oven-repair-4.html
Inside the oven, the heating element is called a "bake" or "broil" element. ... To maintain a set temperature in an electric cooktop, the element is cycled on ... Do not put any cleaning agents or solvents directly on heater elements or surface units. ... A switch will show no continuity when off and good continuity when turned on.
Electric Oven Will Not Heat ' RemoveandReplace.com
removeandreplace.com/2015/.../oven-not-heating-how-to-fix-range-repa...
Aug 24, 2015 - The issue is most likely a bad internal fuse, oven temp sensor, ... oven replacement parts ... Bake and Broil Element Test - Electric Oven Repair ... Dryer Spins But No Heat - How To Troubleshoot Dryer is turning the drum but ... If your dishwasher is completing the wash cycle but will not dry your dishes, we ...
Oven Temperature Not Accurate - Repair Parts ...
Frigidaire stove
Power outage could have shorted out the control panel. Call the power company and put in a claim with your insurance company. Tis happened to me & I was able to reset the oven, even with a glowing bright & dim panel. Thought everything was ok but the upper oven doesn't stay on & the oven probe doesn't work, but it's too late for me to file a claim.
F3 code
I don't think in is unsafe to operate. I worked with boilers that used igniters and a temperature sensors. Usually what these codes mean is (simply error codes ) to guide you which part/s does not function or respond correctly or within a certain time in seconds and brings up this code, but if you get it to ignite, use it like that until you can get someone to do some maintenance on it. Just remember, if your heat is not at the correct temperature, your igniter will fire, but will not be able to ignite the flame.
Meybe lookat this video will make you understand better.
Apr 29, 2014 • Ovens
Why won't my oven let me set the temperature after a power failure?
Good Morning Annette,
I see that you are having trouble with setting the temperature of your oven on your range, model# FGB24S5A, after a power failure. I also see that you have reset your appliance by unplugging it and are receiving an error message of SAG or 5AB. I have looked into the model number that you have listed and it shows as a wall oven. I also do not show either of those error codes you have shown. If you can please get me the model number off your range, so I can better assist. The model number will either be right inside the oven on the back of the door or it may be located inside the bottom drawer. Looking forward to hearing from you.
WP
2answers
GE Monogram oven ZET1SMSS decals rubbed off. I called GE parts and they said they do not just sell the "overlay." They said I would have to purchase the control panel (~$400) to fix the problem. REALL
I had a very similar problem with my oven so I contacted www.ovenlettering.co.uk who supplied me with excellent quality replacement decals with super fast delivery!
The video on the website made it easy to apply them too
Feb 01, 2013 • GE Ovens
1helpful
2answers
Electrolux/Frigidaire stove top decals worn off
1helpful
I HAVE A FRIGIDAIRE ELECRTIC STOVE,GETIN F2&F3 CODES
Hi, these codes represents a fault within the oven temperature sensor. Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
Please rate and god bless:)
Apr 18, 2009 • Ovens
Top Frigidaire Ovens Experts
ZJ Limited
ZJ Limited
Paul Carew
Kell Le
Level 1 Expert
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
