Expert
- Posted on Nov 03, 2009
Re: My Farmall turns over but will not start, it doesn't...
Check for sprak take one plug and put one of the wires on the plug, lay it on the block. make sure its on metal. turn over you shpuld see spark if not take cap off and look at the points use a small screewdriver and slide in between the points key on should see spark if not its the coil
Have you tested to see if it has spark? Have you checked and/or cleaned/replaced the points and condenser? Have you checked the condition of the coil?
Have you checked your points and condenser?
