20 Most Recent
Farmall Cub Tractor Radiator Questions & Answers
No compression
Yes - I suspect your cam is 90 degrees out of time. This will have all the valve events happening at BDC rather than TDC - which equals zilch on the compression guage.
If the cam and crank are not marked, proceed from first principals - pick a cylinder. Position the piston at TDC on that cylinder. Rotate the cam until BOTH valves are off their seats. This is the overlap at the end of the exhaust stroke. The engine is now timed well enough to run - it cannot be more than 1 tooth out in either direction.
You will need to ensure that the ignition is timed also.
I am installing a new radiator on my Cub (SN
30ft/pounds old style gaskets yes,the newer ones you shouldn't have to,but check with the gasket and radiator supplier as they may have a standard on this and how it could affect your warranty down the road
No spark at plug
look for a light color coating on the parts if there is clean it off with sand papper check under the cap to
My Farmall turns over but will not start, it
check for sprak take one plug and put one of the wires on the plug, lay it on the block. make sure its on metal. turn over you shpuld see spark if not take cap off and look at the points use a small screewdriver and slide in between the points key on should see spark if not its the coil
Changing the oil
Hi there..my name is Keith and i restore tractors....and to answer your question..a Farmall Cub hold 3 quarts of oil..i hope this has helped
Farmall 560 idles fine. Gradually dies when a load is put on?
See adjusting throttle governor...
http://farmallcub.com/phpBB2/viewtopic.php?t=100217
Read through entire article and first determine how far out of adjustment, stuck, or worn out the governor is. If not stuck or worn out, try adjusting.
Be careful after first start. Be prepared to shut it down immediately if it runs away. Not likely, but it can happen if some gross mistake is made.
I purchased a Farmall Super A it needed a total rewire thought I had a diagram of the wiring, but when I rewired the tractor will not start.
There seems to be plenty of information available online - the wiring is relatively simple and basic, though the 6 volt version with a 4-wire regulator is a little more complex. The 12 volt conversion with a single wire alternator could hardly be simpler.
It seems the ignition is by magneto. Apart from the stop control these units are self contained and if the engine has a good cranking speed and the magneto (and engine) is in good order the engine should start.
The magneto is usually reliable with just the contact breaker points needing periodic attention. When the magneto fails it is a task for a specialist to sort out as a rewind is often needed...
