I HAD TO REPLACE MY SUB,I ORIGINALLY HAD A SINGLE VOICE COIL SUB BEING RUN BY THE REAR CHANNELS,THE FRONT CHANNELS WERE RUNNING MY 6" BY 9" REAR SPEAKERS.THE NEW SUB HAS DUAL 4OHM VOICE COILS.I NEED TO FIND OUT HOW TO WIRE IT UP. I WOULD GREATLY APPRECIATE YOUR HELP.SINCERELY [email protected]
Just wire one voice coil each into left and right rear respectively, in series with the original rears or if this is too quiet, wire both voice coils in parallel together and connect as per original single coil unit.
As they are 4ohms each they can simply be connected as simple speakers on each rear channel output, since thats exactly what they are, capacitors are used inside to make them react to bass frequencies only. Wiring them up is no different to wiring up a pair of 6x9's.
Testimonial: "HELLO PLANET-X,I CANT BELIEVE I DIDN"T THINK OF IT IN THOSE TERMS.THANKS FOR YOUR HELP AND INSIGHT,GREAT EXPLANATION,YOU SHOULD HAVE BEEN A TEACHER."
