20 Most Recent
MTX Dodge Ram Quad Cab 2002-2003 Thunderform, Loaded with Dual 10 Inch Subs and Amplified, Charcoal Car Speaker Questions & Answers
Brake lights stay on when engine is running. How do I repair??
It sounds as if your brake switch plunger is not making contact at the peddle. The way it works is when it's touching, the light is out and, when you step on the brake peddle the plunger from the switch travels outward and turns the light on. ORThe wires are corroded somewhere in the line (possibly at the rear light housing) whereby the brake light wire is powered through an active 12 volt line when the vehicle is running.
WILL NOT BLOW HOT AIR
check radiator fluid. could be bad thermostat . or possible bad heater core.Switches could be malfunctioning.
Output speed sensor location
Its either mounted to the rear differential or the side of the transmission with 1 bolt.Just unplug the connector then remove the bolt and pull out the sensor.Make sure to reset the computer after replacing the sensor.
Replaced #1 and # 8 coil packs. Now showing
TAKE #8 BACK OFF...REMOVE PLUG MAKE SURE IT IS GOOD AND GAPPED ...SLIGHTLY LUBE PLUG WITH ELECTRICAL LUBE...ONLY WHERE COIL SLIDES ON ...NOT THE THREADS.,..ANTI-SEIZE THREADS LIGHTLY..RE-INSTALL...DOUBLE CHECK CONNECTIONS MAKE SURE YOU ARE GETTING POWER TO IT..( WHILE IT IS RUNNING UNPLUG COIL SEE IF IDLE DROPS ALSO USE TEST LIGHT AT CONNECTOR TO CHECK FOR POWER AT CONNECTOR WHILE IT IS RUNNING ) IF YOU HAVE POWER AND GOOD CONNECTION IT COULD BE INJECTOR FAILURE WHICH WILL HAPPEN INTERMITTENTLY..BUT BEFORE YOU CONCLUDE ANYTHING DO A COMPRESSION TEST ON #8 YOU COULD HAVE A STUCK VALVE AND THE ROCKER ARM HAS CAME OFF.IF IT SHOWS NO COMPRESSION ...OR THE RINGS ARE SNAPPED..I HAVE SEEN IT HAPPEN BEFORE WITH SAME TRUCK.BUT IT WOULD RUN TERRIBLE>>>IF IT RUNS OK BUT STILL SHOWS MISFIRE ALL CONNECTIONS AND PLUGS GOOD.......YOU HAVE BAD INJECTOR/INJECTOR CONNECTION.
I have a 2002 dodge ram 1500 quad cab. the gauges
Check your fuses. This a common thing that can come up often if you have changed from stock stereo equipment to after market, or just because of old fuses.
Once you locate the fuse box, it should give you a diagram of which fuses go to the different lighting systems in your car. Replace them and the problem should be fixed.
If the problem is not fixed from that, then have your wiring checked throughout the truck.
Speedometer is 10MPH fast on 2003 Dodge Ram diesel.
THis is actually programmed into your computer so you are going to need to take it to your dealer or buy a tuner that is capable of this. Its embedded now and its going to stay until it is manually changed sorry. OTHERWISE you could always put bigger tires back on it and it would look mean!! :)
