20 Most Recent MTX T-Form04-05 Chevy Colorado Gray w/10'' sub Car Speaker Questions & Answers
Which is the #2 cylinder on a 3.5L 5cyl chevy
For Chevy Colorado...
Type: 3.5L I-5 (L52)
Firing order: 1 - 3 - 5 - 4 - 2
Hope helps (remember to rate this answer).
2/25/2011 8:35:05 PM • MTX T-Form04-05... • Answered on Feb 25, 2011
What color light indicates power on the MTX 810D amplifier please?
It is too old for online manuals. Any colour light would show it has power and usually a red, green or blue LED. Red is sometimes reserved as a fault condition in conjunction with another power light. https://www.google.com/search?q=mtx+810d+amplifier+manual https://www.google.com/search?q=mtx+810d+amplifier ..
12/27/2023 7:37:11 PM • MTX Car Audio &... • Answered on Dec 27, 2023
How many channels is a mtx 152 amp
Is a 2ch and 210watts peak power
6/24/2022 5:11:46 AM • MTX Car Audio &... • Answered on Jun 24, 2022
2answers
Can I replace a 4700uf 25v cap with a 4700uf 80v cap in my mtx thunder 404?
yes a higher voltage rating is OK lower voltage rating is not good.
6/10/2022 11:29:15 PM • MTX Car Audio &... • Answered on Jun 10, 2022
How to repair a mtx thunder 240 amp
If you have to ask, take it to a repair shop.
12/28/2020 5:26:39 PM • MTX Car Audio &... • Answered on Dec 28, 2020
Mtx 8100d, how do I hook up ?
power to-battery plus ground;; remote''
11/5/2019 3:28:19 AM • MTX Car Audio &... • Answered on Nov 05, 2019
What are the red lights on my mtx tna251 amplifier
THE GREEN LIGHT SHOULD SHOW WHEN AMP IS POWER UP AN RED WHEN IN PROTECTION MODE
9/12/2019 4:23:17 AM • MTX Car Audio &... • Answered on Sep 12, 2019
Where can i get a Manual for a mtx 600 watt terminator amplifier its a tna251
Try eBay Often available there from private sellers
8/25/2019 6:45:34 PM • MTX Car Audio &... • Answered on Aug 25, 2019
I have a mtx tunder series 942 when you hook it up the red light comes on I have the best wire and have checked everything the amp is old school it does have a fuse on it I have one on my power line pls help!!!!!
I was having a similar issue. I checked every wire from the battery to stereo to amp, checked the ground, pulled the stereo to double check the wiring was all correct. Everything seemed good so I thought it had to be my battery not putting out enough power. Tested it and it was good. What it turned out to be was the connection from the power cord to the battery. It had a tiny bit of built up corrosion that was making the amp go into protect mode. Cleaned it up and hooked it back up and has been golden since.
The link attached is pretty straight up on what you need to check for different circumstances. I'm guessing it's a low voltage issue. Good luck
8/23/2019 5:53:57 AM • MTX Car Audio &... • Answered on Aug 23, 2019
I have 3 x 10 inch MTX RT10XDS subs in an enclosure, with a pair of 6x9s 500w pmpo and 2 mids.Whats the best way to wire to the Lightning Audio Strike amp S2.500.4???
you have to first note the ohm load the amp can handle and wire the speaker that ther amp can handle
5/13/2019 1:14:24 AM • MTX Car Audio &... • Answered on May 13, 2019
Okay mtx 4501 lights up no sound
Check the wiring 1st then go down the line...Check speaker connections..Look at your power,ground and remote wire hook up
10/18/2018 5:03:22 AM • MTX Car Audio &... • Answered on Oct 18, 2018
Car Audio & Video Logo
3 questions posted
Top MTX Car Audio & Video Experts
Jose Ramirez
Grand Canyon Tech
Grand Canyon Tech
Steve Sweetleaf
Steve Sweetleaf
Are you a MTX Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • MTX Car Audio & Video
Most Popular Question
2 cylinder 3 5l 5cyl chevy
  • Car Audio & Video
