Whirlpool LGN2000LWH Gas Dryer Logo
Posted on Oct 20, 2009
Whirlpool lgn2000jqo gas dryer won't stay lit
Whirlpool lgn2000jqo gas dryer issue:
heats up initially when you start the cycle, but burner shuts off after about 10 minutes and never comes on again during the cycle. Run the next batch of clothes and the same thing happens - burner for about 10 minutes and then no burner, drum keeps turning. Ideas?
  • bbierenga Oct 22, 2009
    the burner cycles 3 or 4 times successfully and then fails to light again. When that happens the igniter glows but the gas doesn't kick on.
    Do the flame sensors/thermostats prevent the gas valves from opening or can I safely assume the gas valve solenoids need replacing?
Anonymous
Level 1:
  • Contributor 32 Answers
  • Posted on Oct 20, 2009
Anonymous
Contributor
Level 1:
Answers
32
Questions
0
Helped
40598
Points
63
The flame sencer window my need cleaning
Will not stay on will shut off
Whirlpool Gas Oven Will Not Stay Lit - Appliance Repair Forum
forum.appliancepartspros.com/oven.../482851-whirlpool-gas-oven-will-...
Jun 20, 2012 - 2 posts - ‎1 author
My Whirlpool gas oven will light but not stay lit. It has a glow plug igniter that heats up enough to allow the gas valve to open. Once the burner ... oven lights, but does not remain lit
Feb 19, 2013
Oven does not stay lit
Jun 19, 2012
Oven will ignite but will not stay lit
Aug 3, 2010
Gas Oven won't stay lit
Mar 25, 2008
More results from forum.appliancepartspros.com
Jan 04, 2016 • Ovens
2answers
Flame on gas dryer comes on but does not stay lit?
one of 3 issues,1st-the high limit or cycling thermostat could be weak and opening 2nd-the radient sensor eye can be bad or dirty,try cleaning first,both of these are on the burner tube side, 3rd-the gas valve boost and secondary coils could be weak and not holding the gas valve open to let the gas flow,these coils are on the gas valve top body
Whirlpool Cabrio dryer gas does not stay lit after a few minutes.
It sounds like your solenoid coil(s) might be no good. Easy fix and not very expensive.
Gas burner won't stay lit
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 10, 2010 • Dryers
Lgr5620kq1 dryer,heat comes on but does not stay on,
If you find that the dryer initially lights, then goes out and the igniter coil glows, then also goes out, it's the valve solenoid coil, about $25.
There is a temperature limit switch as well. This usually either fails entirely (no heat at all) or operates the burner out of the normal range (often showing up as clothes taking too long to dry).
A clogged dryer vent will cause problems with heat cycling, too.
1helpful
Maytag LDG7400 gas dryer does not stay lit long enough to heat the drum. Can see flame turn on for about 10 seconds then back off for 20 to 30 seconds. Continues cycle of on and off until end of time....
Light sensors detect when burners are lit. If they become blocked with lint, dust, etc., they will not detect the flame and, for safety purposes, automatically shut off the gas flow.
Dust and lint are a dryer's worst enemy. Be sure that all sensing devices (particularly optical sensors) are clear of dust and lint so that light can pass unobstructed into the lens.
If they sensors are all clean, they might be defective. Something is erroneously telling your dryer's control that the burners are not lit and thus the gas supply is shut down.
1helpful
Gas dryer not heating properly
This sounds like the flame sensor is bad to me.
If it does not work properly, the unit will shut off for safety. The machine assumes that the burner did not light and rather than run gas into your house, it shuts off. It may try to start a certain number of times and then shut off.
You may be able to remove and clean it (flame sensor) lightly with a scotch brite pad and it may work properly again.
Otherwise it will need replacement.
This is a very common problem and the part is probably in stock.
Post a comment on your progress as this solution is likely to be useful to many people.
Thanks,
Tim
The problem is not the gas valve.
Whirlpool dryer LGR7646EQ3. Burner lights before pushing start.
The heat is regulated with a Klixon mounted next to the blower housing near the vent pipe so it can judge the temperature of the air coming out of the drum.Right next to it is a melting type fuse. If the dryer runs and gets too hot the fuse will melt.But the dryer will still run. So if the fuse is good(continuity) and the dryer control(cycle) thermostat is also good then you should have power going to the gas valve assembly when the machine is running unless the timer is in the no heat or wrinkle free/cool down mode. When the gas valve assembly is energized the flame sensor mounted outside the burner chamber detects the heat from the ignitor. When the heat is very intense then the sensor shuts down the ignitor and that frees up the power so that the coils can be fully energised and open the gas gates. The gas comes out and hits the red hot ignitor and you have ignition. It stays on for maybe 2 or 3 minutes or until the control thermostat is satisfied and shuts down power to the gas valve assembly.
more here
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Top Whirlpool Dryers Experts
Virgil Watts
Paul Bade
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
