Lens will not auto focus when inside and flash is needed. Works fine outside with no flash
Not sure of you camera model, but the flash will fire momentarily when you try to focus indoors as there is not enough light for the auto focus to work. This is so the camera can determine a distance from the subject to the camera. This is called focus assist (ref to your manual). It will work outdoors as there is enough light and contrast for the focus to work.
Kit lenses included with the camera are notoriously known not to focus well in dark conditions.
SOURCE: Nikon D40X stopped auto-focusing yesterday
I too have the same auto focus issue. But the problem is intermittent.
Called Nikon today. They suggest:
- call when the camera is acting up
- be ready to give them the serial number
Apparently they are available 24 x 7 and will troubleshoot over the phone...
SOURCE: Camera won't shoot with lens on Auto Focus
Talked to canon support, they suggested to send lense in for review/repair. They said it could be the motor, I think it was a gear problem based on the noises and jerkiness of the focusing action while in manual focus (manual focus gave out as well). Cost TBD - "would definately be more than $50. I shopped around and elected to buy a new lense rather than try to hassle with the repair, shipping, insurance, and the wait, etc. Besides, I have a deadline that I need the lense for, so repair at Canon really became a non-option. I think the cost would've been pretty much the same in the end as the new lense, since this wasn't one of the costlier of lenses to begin with.
SOURCE: close up shots won't auto focus.the lens trys to
try using the little throttle that is located just below your on/off switch. if you push that either up/down, it should help you manually focus your subject. It is actually a really fun feature to play around with.
SOURCE: images fine inside but outside natural light images overexposed
CCD is going for Failure !
it starts like this first indoor ok and outdoor over exposed then
indoor pics also when u see them closely turns pink or green in shades then horizontal vert lines appear then completely blank
just check with casio if they have issued service advisory for the CCD failure problem as all others have issued they will do it free of charge
see link
http://www.imaging-resource.com/badccds.html
