Nikon D40 Digital Camera with G-II 18-55mm Lens
Take a brief Survey Take a brief Survey   Add to My Products Add
Problems with Nikon D40 Digital Camera with G-II 18-55mm Lens?
Troubleshooting and Support
Solved Problems for Nikon D40 Digital Camera with G-II 18-55mm Lens RSS Feed Post a New Problem
memory card is locked slide write position
1 Solution
my d40 won`t take pictures
sometimes (and it happens when you least expect) my camera won`t take pictures. It says that everything is ok ( green...
1 Solution
nikon d40 lens
hello, my d40 lens that came with the camera has stopped auto focusing? i believe it's an 18-55. any suggestions? i've...
3 Solutions
Nikon D40 will not take a picture.
The camera turns on as normal but when I try to take a shot it will not function. The battery is fully charged and the...
1 Solution
Nikon D40 will not flash
I have a new (May7,2008) Nikon D40. The flash worked initially but it will no longer flash. It pops up on Auto but does...
1 Solution
no flash, blerry pictures, very slow...
and sometimes shutter gets stuck dose not always take pictures
1 Solution
Zoom ring on 18-55 mm lens is locked/stuck
The zoom ring on my 18-55mm lens (the one that came with my D-40 kit) is locked/stuck. I can't turn it at all. Any...
1 Solution
Unsolved Support Problems
Unsolved Problems for Nikon D40 Digital Camera with G-II 18-55mm Lens RSS Feed Post a New Problem
my nikon D40 says my battery is dead
My Nikon D40 keeps saying Shutter released disabled. Recharge battery. I have two batteries and both are charged. I took...
Post a Solution
Have a Nikon D40x that with a line thru...
My D40x is a little over a year old. Today when we took a picture a green line appeared across the photo. Any idea what...
Post a Solution
Auto focus not working in 18-55mm lens for...
the auto focus stopped suddenly in my 18-55mm lens. my other lenses are working properly. it didn't fall or get hit. any...
Post a Solution
studio lighting
I'm trying to connect My D40 to my studio lights. When I push the test button on the studio Lights the lights will...
Post a Solution
Camera does not operate while in flash...
My Nikon D40 (1-1/2 years old) will not operate with the flash on, not in any mode...It will operate in any mode that...
Post a Solution
D70 internal flash not firing
My Nikon d70 has the internal flash. It pops up when needed and the light goes on like it is going to work, but then it...
Post a Solution
Memory Card Slot Fault
Hi all. Have had my D40 for about 18 months now, but approximately 6-8 months ago, the memory card slot developed a...
Post a Solution
Tips & Tricks
Post a New Tip
WikiManual
Post a New Chapter
Manuals & Guides
Post your Manual or Guide
Specifications
Key Features
Camera TypeSLR/Professional
Image Sensor TypeCCD
Resolution6.24 Megapixel
Optical Zoom3x
Dimensions
Depth2.5 in.
Height3.7 in.
Width5 in.
Weight1.06 lb.
Flash
ISO Speeds200 · 1600
Flash TypeBuilt-In & External
Flash FunctionsAuto Flash · Fill-in Flash · Red-eye Reduction Flash · Slow Sync · Rear Sync Flash
Power Supply
Battery TypeRechargeable Li-Ion Battery
Interfaces
Video InterfaceVideo Out
Interface TypeUSB 2.0
Image Quality
Camera Resolution6.24 Megapixel
Image Resolutions3008 x 2000 · 1504 x 1000 · 2256 x 1496
Lens
Focus TypeAutofocus & Manual Focus
Interchangeable LensInterchangeable Lenses
35mm Zoom Lens27 - 82.5 mm
Exposure Control
Shutter Speed30 - 1/4000 sec
Frames per Second2.5 Frames
Aperture Rangef3.5/f5.6 (w/t)
White BalanceAuto
Storage
Memory TypeSD Card · SDHC Card
Compression ModesFine · Normal · Uncompressed · Basic
Compression TypeJPEG · Raw Image · DCF · DPOF · EXIF 2.1
File Size (High Res.)5.8 MB (22 images on 128MB card)
File Size (Low Res.)0.2 MB (about 640 images on 128MB card)
Viewfinder / Display
ViewfinderOptical (Through-the-lens)
LCD PanelWith LCD Panel
LCD Panel Size2.5 in.
LCD Screen Resolution230,000 pixels
LCD Protected PositionWithout LCD Protected Position
Included Features
Self Timer10 Sec. · 2 Sec. · 20 Sec. · 5 Sec.
Tripod MountWith Tripod Mount
Nikon Contact Information
Main support number1-800-NIKON-UX , 1-800-NIKON-US
Sponsored Links
Loading problems.
Top Digital Camera Experts
techgik
11 solutions
Computer Hardware, Car Audio and Electronics, Cars
Ask Me
Wiz
tjzteddy
10 solutions
Cameras and Photography
Ask Me
Guru
MarkDay
8 solutions
Digital Cameras, Computer Hardware, Networking...
Ask Me
Guru
Repair Service
Find Digital Camera Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
