Samsung Yepp YP-T9 Digital Media Player Logo
Posted on Oct 09, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Was workin fine,did usb recharge now it wont fire up or connect to computer ?
Anonymous
Level 3:
President:
  • Master 803 Answers
  • Posted on Oct 10, 2009
Anonymous
Master
Level 3:
President:
Answers
803
Questions
Helped
230790
Points
2944
Try resetting the device it’s usually a small pinhole on the back or side of the device try holding that in for about 10 seconds
  • Steven Ward Aug 24, 2011
    Webmaster21 is mistaken in this case. The only thing that looks like a pinhole on the YP-T9 is actually the microphone hole. Don't poke that! The reset for the T9 is done by pressing the rec + menu buttons at the same time. Good luck!
1helpful
My philips gogear vibe wont turn on
Reset your GoGear with something sharp like the tip of a pen or the end of a paper clip,
if you're device isn't working properly or there's a frozen display.
Insert the sharp object into the "Reset" hole (located at the bottom of the player), and hold it there until the device turns off.
If resetting the device does nothing to restore the display, access the "Philips Device Manager" through your computer to recover the GoGear.
Click "Start" on your computer, then "Programs," "Philips Digital Audio Player," "Aria Device Manager," and then "Philips Device Manager."
This will launch the "Philips Device Manager." Make sure the GoGear is turned off completely. Connect your GoGear to your computer while holding down the "Volume Up" button.
Continue to hold the "Volume Up" button on your GoGear, until the "Philips Device Manager" recognizes the device and enters recovery mode.
Click the "Repair" button when it appears on your computer, then folow the steps to fully recover the GoGear.
Properly disconnect your GoGear from your computer and restart the device.
Recharge your device if your GoGear dies suddenly while playing.
Connect the GoGear to your computer via the supplied USB cord.
Plug one end of the USB cord into a functional, open USB port on your computer. Plug the free, smaller end of the USB cord firmly into the small USB jack on your GoGear and turn your computer on.
This will begin the charging process of your GoGear.
If recharging doesn't work, the battery may need to be replaced.
Check that your GoGear isn't in standby mode. Hold the "Power" button for two seconds to turn it back on.
hope this helps
When I connect My Samsung VP-D77i Camcorder to my Laptop I always get a message saying "cant open camera device". My Laptop does not have a fire wire port but only with USB ports. It has Windows 7 Pre
First, try attaching the camcorder via usb cable with the camera OFF, then turning it on. This may trigger Windows to activate the driver scanner and activate the driver. If you've been attaching with camcorder off, try attaching with it on, to see if that activates driver installation.
If that doesn't work, you may have a low-power usb plug; often the usb ports in the back of the computer put out more juice than the handy ones on the front. You may also need a shorter and more robust usb cable; I've found with various cameras and phones that certain usb cables work fine for recharging but won't necessarily provide adequate data transfer.
1helpful
2answers
My sansa fuze wont charge
Some USB ports cannot supply enough power to charge the Fuze. I had the same problem. I worked around it by getting a wall charger from RadioShack.
Sansa clip wont power up unless hooked up to usb
http://www.sandisk.com/media/175960/clip_um_0608_eng.pdf
Windows XP SP2
• Windows Media Player v10
• Intel Pentium class PC or higher
• CD-ROM drive
• USB 2.0 port for hi-speed transfers and charging
Make sure HOLD button is not on.
Battery
The Sansa
Clip player comes with an internal rechargeable battery. To use the player for
the very first time, remember to fully charge the battery. You can charge your Sansa
player through the USB port of your computer, a car adapter (not included) USB port, or AC
adapter (not included) USB port.
Charging
To charge the battery, please follow these steps:
1. Connect the larger end of the USB cable into an available USB port on the
computer.
2. Connect the smaller end of the USB cable into the Sansa
Clip player.
3. The computer must be on for most USB ports to charge your battery. Your
Sansa
will show connected and the yellow charging indicator will appear.
The battery level indicator will blink while charging. You will not be able to
play while connected to the computer USB.
4. To stop recharging, simply disconnect the cable.
The battery can also be charged using an AC adapter (not included) or a car adapter
(not included) and you will be able to play your device while charging with one of the
adapters.
NOTE: Some low-power USB ports may not be able to provide enough charge
power. Also note that the rechargeable batteries are not replaceable.
2helpful
Help!I cant charge my Mps with the USB cable...
Ok, wich USB you are conectting? Cause if you are connectting in the front, it don´t have enought current to recharge the mp3, but wether you connect in the back USB , it will works very good. If you have a Notebook, connect in other USB until you find the correct one. I Think that i Help You, Good Luck.
1helpful
My zen v plus wont turn on
Zen V is dead
"If your Zen V is dead, wont respond to anything, try this, plug it in to the computer, hold the power switch in the on position, THEN trigger the reset button, worked like a charm for mine, I had thought it a lost cause."
1helpful
Wont power up
Same unit, same problem. I found that when the internal batt is dead current draw on the USB port is not enough to recharge. I have a USB car adaptor (it is for my kids PSP ) and use it to recharge the batt when it goes completly dead. I keep a eye on the remaining batt life and charge it via the computer USB before it gets to low
My sansa e250 wont charge all the way
Well ... i will show you different way to recharge any plear with USB recharge options...
Now... first sorry for my english but... iam from Bulgaria ...
second: you'll need a adaptor from GSM mobile with 5 or equivalent voltage output.Next step: remove part of cover cable on USB cable on mp3/4 and search for red cable it is "+" split with plus on the adaptor of GSM, next ... "-" it must be arround all cables on mp3's USB cable, split with "-" on GSM adaptor. Isolate fine and when you connect GSM adaptor into contact and USB cable into mp3 .. the mp3 will charge fine! Its possible and in manual of SANSA is writen! :) I try and successed!
congratulations - spellsingero, Bulgaria
Cannot charge or copy music onto the sansa e270
You might not have the battery "seated" correctly. Try removing and replacing the battery.
Top Samsung Audio Players & Recorders Experts
ZJ Limited
ZJ Limited
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
