20 Most Recent Samsung Yepp YP-T9 Digital Media Player Questions & Answers
It's not a hard work that you can have a try powerful program Leawo Tunes Cleaner. Leawo Tunes Cleaner is a professional duplicate music remover.
Step 1. Run Tunes Cleaner and Scan Duplicate Songs
After kicking off Leawo Tunes Cleaner for Windows, click the "Clean-up Duplicates" entry. The program provides 2 duplicates scanning modes: Quick Scan mode and Deep Scan mode. Select one of them to scan duplicate songs.
Step 2. Add Music Files for Duplicates Removing
You could delete duplicate songs in iTunes music library by directly clicking "Scan iTunes" button or click "Add" button to load music files for duplicates removing. Or you could directly drag music files from your local folder to the software for duplicates removing.
Step 3. Start Deleting Duplicates
After loading source music files, click the "Scan" button on the upper-right corner to start scanning duplicates. The program would display all duplicates clearly and suggest what to remove. You could decide which duplicates to delete by checking them and then click the "Remove" button to remove duplicate songs.
tunes-cleaner-scan-result-gwujvob1wsqcwi5j4bnkubbk-3-0_0.jpg For more details, check: How to Delete Duplicate Songs
Samsung Yepp... | Answered on Apr 24, 2019
Samsung Secret Codes Software version: *#9999# IMEI number: *#06# Serial number: *#0001# Battery status- Memory capacity : *#9998*246# Debug screen: ...
Samsung Yepp... | Answered on Feb 21, 2019
Yp-t9 can only play svi files.First convert those mp4 files into avi or wmv files.And use samsung media studio to put them into your yp-t9.The samsung media studio will convert ai and wmv files to svi.Or jus try to convert those mp4 files with Samsung media studio.It converts sometimes.
Samsung Yepp... | Answered on Dec 17, 2018
Those red lines are telling you the word is misspelled. Correct the spelling and the red lines will go away.
Samsung Yepp... | Answered on Jul 31, 2016
You need to punch in sequence of buttons: left+left, right+right, up, center, down This will make you to format the device completely. Once the format is done, you need to reset the player by pressing Record and Menu, both at the same time. Then turn the player ON, it will display message "USB device", that means, player has nothing on it and it is working as mass storage device only. Now you need to download the firmware from www.samsung.com and transfer two files MUON.ROM and SYSDATA.bin to root. Again reset the player by above mentioned sequence. turn the player on, and now you are back in business. Have a wonderful day. Enjoy Samsung player. Samsung rocks. - CHAMP
Samsung Yepp... | Answered on May 30, 2014
Complete Solution - includes fix for Bluetooth.
You will need to execute a number of steps to do this:
1 - obtain a copy of the latest firmware from http://www.samsung.com/uk/support/search/supportSearchResultView.do?group=&group_cd=&type=&type_cd=&subtype=mp3others&subtype_cd=&model_nm=YP-T9&dType=D&vType=L&mType=&model_cd=&menu=download&prd_ia_cd=&disp_nm=YP-T9
or (even better) - go to the international site and download a copy of YP-T9 V1.80.zip
2 - Reset - Power off the yp-t9 using A-B and MENU pressed together - hold down A-B and press the POWER button to enter the low-level format mode - press LEFT LEFT RIGHT RIGHT UP CENTRE DOWN - the yp-t9 will now reformat - power off using A-B and MENU together
3 - reload firmware - Power on normally and connect to PC as a USB drive. Move the two files you just downloaded (MUON.ROM and SYSDATA.BIN) into the root of the USB drive - Safely remove the drive - Power on the yp-t9 and allow it to re-install the firmware
If you want to restore Bluetooth functionality you will also need to perform the following steps:
4 - pop the four rubber plugs out of the back of the unit - with a small phillips screwdriver remove the four screws - insert your fingernail into the seam of the unit on both sides and pop off the back - gently (slowly) remove the battery taking care not to place any strain on the connecting wires - copy dowm the 12-digit number on the label under the battery (starts 0016xxx...) - replace battery, back, screws and plugs.
5 - using text editor create a file with the 12 digits (use upper-case letters where appropriate) followed by <enter> key - save it as BT_MAC_ADDR.TXT
6 - connect the yp-t9 and open it using Right click on Start and Explore - find the yp-t9 and drag a copy of BT_MAC_ADDR.TXT into the SYSTEM folder - Safely remove - power on normally.
Hope this helps
Chris
Samsung Yepp... | Answered on Apr 11, 2014
I think holding down menu and the record button at the same time should fix it. I read the best solution and it just turned on. I was having the same problem, mine would not turn on either but just try pressing and holding down the record and menu button for about 5 seconds.
Samsung Yepp... | Answered on Nov 21, 2013
I solved this problem by hooking my device up to my computer and opening Windows Media Player. On the left hand side it will show the name of your device under your playlists. I right clicked my devices name and chose to format it. That erased all of the songs as well as pictures that I had put on the device, and it only took a few seconds.
Samsung Yepp... | Answered on Sep 20, 2012
Hello Deanna,
To change it, go to Menu, Messages, Create New (press center button)
The lower right hand you will see mode you are using now.
The dash ABOVE the END key, press it and click on the ABC mode or whichever
mode you prefer.
Samsung Yepp... | Answered on Oct 06, 2011
Try resetting the device it’s usually a small pinhole on the back or side of the device try holding that in for about 10 seconds
Samsung Yepp... | Answered on Aug 24, 2011
Try looking here http://www.samsung.com/us/support/downloads/global , and you should be able to find the software and drivers for your player. It's a free download, and I believe the Emodio software is the current download for your player. Good Luck!
Are you converting the videos to the .svi format that the T9 recognizes? If not, try this:
A. Get the T9 software from the samsung support site and install it on your computer.
B. Let the software find the video on your computer.
C. Right click on the desired video and select "convert" from the menu.
D. After the conversion drag and drop the .svi video into the Video folder in the T9's memory.
E. Enjoy your video!
Good Luck!
Samsung Yepp YP-T9 Digital Media Player Logo
233 questions posted
Top Samsung Audio Players & Recorders Experts
Mike Duncan
Mike Duncan
Marvin
Marvin
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
YP Samsung
  • YP Samsung
Most Popular Question
samsung yp t9 but lost software
  • Audio Players & Recorders
